Seem to be having an issue I cant resolve. I've only use the timer software on a 18F2550 and it worked perfectly. I'm now using a 18F1320 and I've ran into an issue when compiling.
ERROR Line 23: Redefinition of VAR. (DT_INTS-18.bas)
ERROR Line 24: Redefinition of VAR. (DT_INTS-18.bas)
ERROR Line 25: Redefinition of VAR. (DT_INTS-18.bas)
Which are these lines in the code:
wsave       var byte  BANKA  SYSTEM   ' location for WREG
ssave       var byte  BANK0  SYSTEM   ' location for STATUS register
bsave       var byte  BANK0  SYSTEM   ' location for BSR register
I am unsure as to what the problem is and where to start.
I'm using PBP 2.60A and MCS 3.0.0.5
