Elapsed Timer Demo
Results 1 to 40 of 112
    Default Re: Elapsed Timer Demo
    No, the Elapsed Timer Demo can only have one timer at a time.
    The same concept can be used to create multiple timers, but this demo doesn't do that.
    Since the ON and OFF periods can't happen at the same time...
    When one period is finished, Reset the timer and measure the next period.
    You only need one timer.
    You don't have to stop and start the timer, just GOSUB ResetTime, and the time will revert to 0d-00:00:00.0 and keep counting.
    Use it like a Stopwatch.
    The interactive LCD on this page shows how it works. (Click on the "GOSUBs")
    http://www.darreltaylor.com/DT_INTS-14/elapsed.html
    But that page is for the DT_INTS version of the Elapsed Timer.
    Feb 2004
    Michigan, USA
    Well I've had an implementation of this working great for months now. Its counts down 20 minutes, turns off the output, flashes an LED using the pause command, then sits there waiting for the input to start again.
    I need to add a feature now though. As the time reaches 15 minutes, I need it to flash an LED at 2Hz while still counting down and turning off at 20 minutes.
    Currently the code is like this:
    IF MinutesChanged THEN
        MinutesChanged = 0
        IF Minutes = 20 THEN
        HPWM 1, 0 , 30000
        POWER = 0
        LEDS = 0
        CURRENT = 0
    If I change it to this will it do what I need it to do? Second thing is if it will, how do I flash an LED while still running the main program? I am using HPWM already.
        MinutesChanged = 0
        IF Minutes = 15 THEN
        GOSUB Flashyflashy
        MinutesChanged = 0
        HPWM 1, 0 , 30000
        POWER = 0
        LEDS = 0
        CURRENT = 0
    I'm not that familiar with the code but the way you suggest will only call FlashyFlashy when minutes is 15 - not more, not less. If you want FlashyFlashy to keep executing all the way to 0 you need IF MINUTES <= 15 THEN You could also streamline it a bit, there's no real need to check and reset MinutesChanged twice, perhaps something like
        MinutesChanged = 0
        IF Minutes <= 15 THEN
        GOSUB Flashyflashy
        HPWM 1, 0 , 30000
        POWER = 0
        LEDS = 0
        CURRENT = 0
    Jim,
    I think that'll just flash it once at the 15 minute point.
    This should work.
     Flashing VAR BIT
            MinutesChanged = 0
            IF Minutes = 15 THEN Flashing = 1
                Flashing = 0
                HPWM 1, 0 , 30000
                POWER = 0
                LEDS = 0
                CURRENT = 0
        IF Flashing THEN
            SELECT CASE Ticks
              CASE IS <25 : HIGH LED
              CASE IS <50 : LOW  LED
              CASE IS <75 : HIGH LED
              CASE ELSE   : LOW  LED
            END SELECT
    Feb 2004
    Michigan, USA
    Darrel, can this be used as a countdown timer with the time left updated each second and displayed on a LCD?
    Thanks.
    It Can ...
    But you would need to create the count down routine.
    The demo only counts up.
    Feb 2004
    Michigan, USA
    OK thanks. I will play around with it and see what mess I can create.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Get elapsed time while TIMER samples pulses
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 17:27
  3. Elapsed Timer Demo in a PIC12F675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 21st November 2008, 01:01
  4. Totally Baffled with Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 22:01
  5. Darrel Taylor Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 02:22
