How to detect variable decrease moment?
Results 1 to 6 of 6
    Default How to detect variable decrease moment?
    Hello.
    I'm doing a task, where variable presents certain data (changes every second). I have to capture a moment, when it starts to decrease.
    My code is here:
    COMPARER:
    IF OLD>NEW THEN GOTO OTHER TASK
    PAUSE 1
    OLD=NEW
    GOTO COMPARER
    But isn't there some kind of statement, to make this shorter?
    Default Re: How to detect variable decrease moment?
    Have a look at the PB manual
    http://melabs.com/resources/pbpmanual/5_75-5_76.htm#572
    While..Wend
    Apr 2011
    Welches, Oregon
    You did not specify if you mean "shorter" as in with fewer lines of code or "shorter" as in faster...
    Here is a thread you may find interesting: http://www.picbasic.co.uk/forum/showthread.php?t=5335
    Also, you may look at the Pauseus statement.
    May 2008
    Italy
    COMPARER:
    PAUSE 1
    OLD=NEW
    GOTO COMPARER
    If you loop inside the snippet how do you feed the variable "NEW" with the updated value?
    Al.
    @ first ... your processor will be able to see a change only AFTER data have been collected ( La Pallice, french philosopher ).
    from that, if you collect data once a second ( as written @ post #1 ) no need to scan value @ each millisecond ...
    just place your test ONCE after data collection ( ADC conversion or serial value received ) and you won't loose any time !!!
    no need to have a watching loop nor ...
    (nevermind)
  1. How to detect sound direction?
    Last Post: - 13th December 2008, 04:53
  2. Detect 240V with a PIC
    Last Post: - 28th October 2008, 20:21
  3. Detect Signal
    By angrysmileyface in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 00:28
  4. What is the easiest RTC chip of the moment?
    By paxmowa in forum Off Topic
    Last Post: - 13th October 2006, 00:41
  5. Low Voltage Detect
    By Brian in forum mel PIC BASIC Pro
    Last Post: - 1st April 2005, 16:46
