Counting Timer0 and Timer1 overflows without any interrupt handler
Results 1 to 33 of 33
Threaded View
  1. #11
    Jan 2007
    Default Re: Counting Timer0 and Timer1 overflows without any interrupt handler
    Hmmmmm.
    I was thinking I was going to have to use a mosfet solid state relay at the input from the frequency source, so that I could pump Timer0 through the remaining clock cycles necessary to raise its flag again.
    I can see how pulling the Timer0 input pin high will disable the incoming clock from the frequency source.
    But I can't see how it could be used to pump the remaining cycles to get Timer0 to its next overflow since there is no way to dis-engage the frequency source signal. The remaining clocking and the frequency source would conflict with one another.
    Additionally, I was wondering if there is another way of pumping Timer0 to overflow, by using an internal software loop rather than doing it through an external clocking pin? I was wondering if a routine of adding 1 to TIMRL register and testing for a TMR1IF flag might work just as well.
    Unless I'm wrong that the intent is to pump Timer0 from an output pin from the PIC?
    Thanks :-]
  1. Expanding Timer1 counting range
    By sycluap in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2014, 22:00
  2. PIC18 timer0 interrupt handler, still not getting it
    By ImAnEE in forum mel PIC BASIC Pro
    Last Post: - 30th April 2011, 00:25
  3. DT-INTs Interrupt handler question
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 8th January 2010, 00:06
  4. Synchronising Timer0 and Timer1
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 9th April 2008, 23:12
  5. 16F690 TIMER0 and TIMER1
    By nickdaprick in forum mel PIC BASIC
    Last Post: - 18th April 2007, 14:49
