How to do the "SerIN" and "SerOut " for the usb ?
Results 1 to 2 of 2
    Nov 2008
    sao paulo - brasil
    Unhappy How to do the "SerIN" and "SerOut " for the usb ?
    Dear Friends,
    I am making the communication as in the code below saw rs232.
    I want to do using the usb and the pic18f4550 I don't get.
    Some of the friends could help with the code
    In advance thankful,
    Vicente.
    Excuse my English I am Brazilian.
    ;Definicoes 18F4550
    @ __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    @ __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_3_2L & _VREGEN_ON_2L
    @ __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    @ __CONFIG _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H & _CCP2MX_ON_3H & _LPT1OSC_ON_3H
    @ __CONFIG _CONFIG4L, _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L & _STVREN_OFF_4L & _DEBUG_OFF_4L
    @ __Config _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    @ __Config _CONFIG5H, _CPD_OFF_5H & _CPB_OFF_5H
    @ __Config _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    @ __Config _CONFIG6H, _WRTB_OFF_6H & _WRTC_OFF_6H & _WRTD_OFF_6H
    @ __Config _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    @ __Config _CONFIG7H, _EBTRB_OFF_7H
    INCLUDE "modedefs.bas"
    Include "cdc_desc.bas"
    Define OSC 48
    ;********* PORT A
    ADCON1 = %00001111 ;Turn off all AD's
    TRISA = %11010100 'PortA
    PORTA = %00000000
    ;********* PORT B
    INTCON2.7=0 ; Enable PORTB pullups
    TRISB = %11011111 'PortB
    PORTB = %00000000
    ;********* PORT C
    TRISC = %10111111 'PortC
    PORTC = %01111111
    ;********* PORT D
    TRISD = %11111111 'PortD
    PORTD = %00000000
    ;********* PORT E
    TRISE = %11111111 'PortE
    PORTE = %00000000
    ; DEFINICOES DAS CONSTANTES E VARIAVEIS *
    define i2c_sclout 1
    define i2c_hold 1
    define i2c_slow 1
    define ser2_bits 8
    define shift_pauseus 100
    ;***************************** Alias Dos Pinos *******************************
    SDA_Chave VAR PORTB.4
    SCL_Chave VAR PORTB.5
    ;***************************** Comunicacao serial 232
    Modo_232 con 16390
    Ctrl_Chave con %10100000;Endereco Fisico
    ;*************** DEFINICOES DAS VARIAVEIS
    Hc var byte[150]
    Work_Word VAR word
    K VAR BYTE
    X VAR BYTE
    ; TECLA *
    Tecla:
    SerIn2 portc.7,Modo_232,200,Tecla,[wait($AA),x,k] ;
    if x="P" and k="O" then
    high porta.3;led
    goto Tecla
    if x="E" then
    for work_word=20 to 1307 step 13
    I2cread sda_chave,scl_chave,Ctrl_Chave,work_word,[hc[100],hc[101],hc[102],hc[103],hc[104],hc[105],hc[106],_
    hc[107],hc[108],hc[109],hc[110],hc[111],hc[112]]
    SerOut2 portc.6,Modo_232,["!",dec5 work_word,",",dec2 hc[100],dec2 hc[101],dec2 hc[102],dec2 hc[103],dec2 hc[104],_
    dec2 hc[105],dec1 hc[106],dec1 hc[107],dec1 hc[108],dec1 hc[109],dec1 hc[110],dec1 hc[111],dec3 hc[112],"&"];
    next
    SerOut2 portc.6,Modo_232,["K"]
    goto tecla
    goto Tecla
    Aug 2008
    Portugal
    Default Re: How to do the "SerIN" and "SerOut " for the usb ?
    Thanks and Regards;
    Gadelhas
  1. Replies: 0
    Last Post: - 14th November 2013, 03:32
  2. Replies: 3
    Last Post: - 15th October 2012, 08:06
  3. SEROUT or HSEROUT "ODD" parity
    By RFsolution in forum Serial
    Last Post: - 9th December 2006, 10:34
  4. Serout "onewire.bas"
    By puru in forum mel PIC BASIC Pro
    Last Post: - 6th July 2005, 00:14
  5. Replies: 1
    Last Post: - 16th February 2005, 20:05
