Need help: hserin, serin and serin2 does not work for me
Results 1 to 6 of 6
    Feb 2014
    Aarhus, Denmark
    Default Need help: hserin, serin and serin2 does not work for me
    Hi all
    Programming PIC18F45K22 @ 64Mhz. Can't read any kind of input in to it.
    (hserout, serout, and serout2 works in the three code examples)
    It is not responding on any kind af input from a terminal
    Don't understand what is wrong?
    ' Hserin test
    ' For PIC 18F45K22 with PLL
    ' Compiler used: PBP3
    ' Assembler used: MPPASMX
        CONFIG  FOSC = INTIO67        ; Internal oscillator block
        CONFIG  PLLCFG = ON          ; Oscillator used directly
        CONFIG  PRICLKEN = OFF        ; Primary clock can be disabled by software
        CONFIG  PWRTEN = OFF          ; Power up timer disabled
        CONFIG  BOREN = SBORDIS       ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  BORV = 190            ; VBOR set to 1.90 V nominal
        CONFIG  WDTEN = ON            ; WDT is always enabled. SWDTEN bit has no effect
        CONFIG  WDTPS = 32768         ; 1:32768
        CONFIG  CCP2MX = PORTC1       ; CCP2 input/output is multiplexed with RC1
        CONFIG  PBADEN = OFF          ; PORTB<5:0> pins are configured as digital I/O on Reset
        CONFIG  CCP3MX = PORTB5       ; P3A/CCP3 input/output is multiplexed with RB5
        CONFIG  HFOFST = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  T3CMX = PORTC0        ; T3CKI is on RC0
        CONFIG  P2BMX = PORTD2        ; P2B is on RD2
        CONFIG  MCLRE = EXTMCLR       ; MCLR pin enabled, RE3 input pin disabled
        CONFIG  STVREN = ON           ; Stack full/underflow will cause Reset
        CONFIG  DEBUG = OFF           ; Disabled
        CONFIG  CP0 = OFF             ; Block 0 (000800-001FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (002000-003FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (004000-005FFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (006000-007FFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-001FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (002000-003FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (004000-005FFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (006000-007FFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    DEFINE OSC 64
    ' Setup PLL for 64 MHZ
    OSCCON = 110100 ; 16 mhz (NOTE: SCS=0 so PLL works)
    OSCCON2.7 = 1
    OSCTUNE.6 = 1 ;  PLL enable Mhz * 4
    ' Set receive register to receiver enabled
    DEFINE HSER_RCSTA    90h
    ' Set transmit register to transmitter enabled
    DEFINE HSER_TXSTA    20h
    ' Set baud rate
    DEFINE HSER_BAUD    9600
    DEFINE  HSER_CLROERR 1  ' Auto clear over-run errors
    char Var byte  ' Storage for serial character
    Pause 2000
    start:
           Hserout ["Hello World", 13, 10] ' Send text followed by carriage return and linefeed
    mainloop:
           Hserin 10000, start, [char]    ' Get a char from serial port
        Hserout [char]        ' Send char out serial port
           Goto mainloop        ' Do it all over again
    ' Serin test
    Include "modedefs.bas"
    DEFINE OSC 64
    OSCCON2.7 = 1
    TRISC = 000000
    DEFINE SER2_BITS 8
    pause 2000
    start:
       serout PORTC.6, T9600, ["Hello World", 13, 10] ' Send text followed by carriage return and linefeed
    mainloop:
       serin PORTC.7, T9600, 10000, start, [char]    ' Get a char from serial port
       serout PORTC.6, T9600, [char]        ' Send char out serial port
    ' Serin2 test
    DEFINE OSC 64
    OSCCON2.7 = 1
    TRISC = 000000
    DEFINE SER2_BITS 8
    pause 2000
    start:
       serout2 PORTC.6, 84, ["Hello World", 13, 10] ' Send text followed by carriage return and linefeed
    mainloop:
       serin2 PORTC.7, 84, 10000, start, [char]    ' Get a char from serial port
       serout2 PORTC.6, 84, [char]        ' Send char out serial port
    Feb 2014
    Aarhus, Denmark
    Default Re: Need help: hserin, serin and serin2 does not work for me
    I have found the error
    I had forgotten to put the ports for digital input / outputs
    Then I added:
    ANSELA = 0
    ANSELB = 0
    ANSELC = 0
    ANSELD = 0
    ANSELE = 0
    - Now works test programs with hserin and serin2 except with the serin. But I can live with it. Now I can move on.
    - Jacob
    Feb 2014
    Aarhus, Denmark
    Working code files:
    Feb 2012
    PERTH AUSTRALIA
    also check your setting for OSCCON2.7 =1 , I think that bit is status bit to be read , not one that is set ???
    bit 7 PLLRDY: PLL Run Status bit
    1 = System clock comes from 4xPLL
    0 = System clock comes from an oscillator, other than 4xPLL
    Feb 2012
    PERTH AUSTRALIA
    also be aware of the eerata for this chip and the The EUSART asynchronous operation has a
    probability of 1 in 256 of missing the Start bit
    edge for all combinations of BRGH and BRG16
    values, other than BRGH = 1, BRG16 = 1.
    All silicon prior to A5
    http://ww1.microchip.com/downloads/e...Doc/80498F.pdf
    Feb 2014
    Aarhus, Denmark
    Ok. Thanks for advice :-)
    - Jacob
  1. Getting SERIN2 to work?
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2009, 20:10
  2. HSERIN vs Serin2
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 16:50
  3. Serin to Serin2 ??
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 03:56
  4. Should I use serin2 or HSERIN?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 20th April 2007, 16:05
  5. serin and serin2
    By rastan in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2005, 13:10
