Hello !
Since I have good results with "wired remote for Pioneer HU" (see : http://www.picbasic.co.uk/forum/showthread.php?t=15229 ) one friend ask me to build something similar for his Alpine ...
I found a good topic here : http://www.mp3car.com/input-devices/...ol-pinout.html , where it's described the "protocol".
I intend to use the same hardware : PIC 16F628A and remote control stalk near the steering wheel, from Renault.
But...I need help to put in PBP this :
So if "0" is low for 1000 us, and "1" is high for 500 us AND low for 500 us, how can I write the code ?!Code:Vol Up 110101111101101110101011110110111101011011010101 Vol Dn 110101111101101110101011011011011111011011010101 Mute 110101111101101110101011101011011110111011010101 Pst up 110101111101101110101011101010111110111101010101 Pst dn 110101111101101110101011010101011111111101010101 Source 110101111101101110101011101101111101101101010101 Trk up 110101111101101110101011101110111101101011010101 Trk dn 110101111101101110101011010111011111101011010101 Power 110101111101101110101011011101111110101101010101 Ent/Play 110101111101101110101011010101111111110101010101 Band/prog 110101111101101110101011011010111111011101010101 Note that the same series of 1's and 0's is at the start and end of each command, so here are the unique parts of each: (Start) 110101111101101110101011 Vol Up 11011011110101101 Vol Dn 01101101111101101 Mute 10101101111011101 Pst up 10101011111011110 Pst dn 01010101111111110 Source 10110111110110110 Trk up 10111011110110101 Trk dn 01011101111110101 Power 01110111111010110 Ent/Play 01010111111111010 Band/prog 01101011111101110 (End) 1010101
Something like this (pseudo-code):
I need "a clue" ! Thanks in advance !!!Code:;(Start) 110101111101101110101011 ; Vol Up 11011011110101101 check: select case key case 1 ; volume down portb.7 = high pauseus 500 portb.7 = low pauseus 500 ' this is first "1" portb.7 = high pauseus 500 port.7 = low pauseus 500 ' this is second "1" ... so on, so on ?!?
