I need help with i2c memory
Results 1 to 18 of 18
    Jun 2005
    Wisconsin
    Talking
    Make your addr a word variable, not byte.
    Also make sure you assign a value to your addr before the write command.
    Example:
    Addr=3
    I2Cwrite sda,scl,contW,addr,[x] 'should write 3 to address 0, right?'
    pause 10
    Finally you may want to add DEFINE I2C_SLOW 1 if things are still not working.
    Basically if your wired like the manual says and you do the above it works great.
    Feb 2004
    Germany
    Try this:
    addr var word
    sda var PORTB.0
    scl var PORTB.1
    cont con %10100000
    x var byte 'test data'
    addr=%00000000
    x=3 'test data is the number 3'
    I2Cwrite sda,scl,cont,addr,[x] 'should write 3 to address 0, right?'
    pause 10
    I2Cread sda,scl,cont,addr,[x] 'should read the data'
    pause 10
    serout Portb.2,4,[DEC x] 'displays data on an LCD'
    regards
    Ralph
    Jun 2005
    Wisconsin
    Also keep in mind if your hoping to see the number three on the LCD you will need to modify your code a bit.
    serout Portb.2,4,[DEC x] 'displays ASCII version of data on an LCD'
    Jun 2005
    Quote Originally Posted by NavMicroSystems
    Try this:
    addr var word
    sda var PORTB.0
    scl var PORTB.1
    cont con %10100000
    addr=%00000000
    pause 10
    pause 10
    when i go to compile i get "bad expression" on serout Portb.2,4,[DEC x]
    i am using microcode studio.
    Jun 2005
    Wisconsin
    You are missing the two pull-up resistors that are required.
    Try wiring it identical to the Melabs user manual. This is your best shot at getting it to work. I have included the drawing in this post.
    Jun 2005
    Quote Originally Posted by DynamoBen
    you are talking about the 2 pull up resistors on scl and sda correct? they are there. as far as i can tell the only difference between what i have and your picture is the cap from vdd to ground on pin 14. ill put that in and see what happens..
    Jun 2005
    Wisconsin
    You may want to wire it exactly like the drawing for testing purposes.
    Jun 2005
    alright, ive spent some more time on this, with my new lcd. redid the circuit to the schematic posted, still not working for me, it seems it is not writing at all,
    do i need to set trisb to something? thats my current line of thought,
    thx
    Quote Originally Posted by -c3-
    what about serout Portb.2,4,[#x]???
    Jun 2005
    Quote Originally Posted by mister_e
    that compiles, only problem now is i killed my lcd...... needless to say, from now on i will be a little more careful of which voltage supply i am using.... little puffs of smoke are bad....
    Jun 2005
    Tried that, still nothing. it makes me wonder if there is something with my circuit i am missing...(i think it is right...)
    if any one wants to check the wiring (its not messy)
    chip pinouts included
    http://www.siue.edu/~bluttin/circuit.htm
    thanks
    the middle chip is the uln2803, its just driving the leds, ive tried it connected, and unconnected.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  4. A help with Write/Read a I2C memory
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 28th March 2008, 14:53
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
