I need help with i2c memory
Results 1 to 18 of 18
Threaded View
    Jun 2005
    Default I need help with i2c memory
    For my senior project we are using a pic16f84. A large part of the project is storing data in a serial memory chip usint i2c. ive spent 5ish hours trying to figure this out. went through data sheets and searched online, still no success. i am confident my circuit is wired correctly. any help would be greatly appriciated.
    the memory used currently is microchip's 24AA512, we also have a 24c01 laying around to play with as well.
    i have 2 pull up resistors (5.1k) on scl and sda
    write protect is grounded
    here is my code,
    addr var byte
    sda var byte
    scl var byte
    contR con %10100001
    contW con %10100000
    x var byte 'test data'
    sda=PORTB.0
    scl=PORTB.1
    addr=%00000000
    x=3 'test data is the number 3'
    pause 100 'pause just for fun'
    I2Cwrite sda,scl,contW,addr,[x] 'should write 3 to address 0, right?'
    pause 10
    I2Cread sda,scl,contR,addr,[x] 'should read the data'
    pause 10
    serout Portb.2,4,[x] 'displays data on an LCD'
    Thanks!
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  4. A help with Write/Read a I2C memory
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 28th March 2008, 14:53
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
