LM71 reads garbage sometimes.
Results 1 to 13 of 13
    Default Re: LM71 reads garbage sometimes.
    Do you have the pins on the 71 pulled high?
    No, I should?
    Tried 4.7k pull-ups on all pins, does not helps.
    May 2008
    Italy
    From cs low to the out of data the maximum time delay is 70 ns. you are using 5 ms. play with that delay using pauseus.
    See data sheet timing table.
    Cheers
    Al.
  1. ds18s20 reads incorectly
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 28th May 2014, 19:03
  2. 5v on analog pin but reads value
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th November 2012, 03:41
  3. Garbage in from RFID
    By lilimike in forum Serial
    Last Post: - 6th December 2009, 14:55
  4. EEPROM writes and reads
    Last Post: - 19th November 2008, 01:56
  5. SEROUT Just Garbage!
    By Kman in forum mel PIC BASIC Pro
    Last Post: - 6th September 2006, 19:42
