Help with Hellebuyck reverse flashing led
Results 1 to 5 of 5
    Dec 2013
    Default Help with Hellebuyck reverse flashing led
    This is what is in his book but it will not programme
    symbol led = b0
    pins = %00000000
    dirs = %11111111
    for led = 0 to 7
    high led
    low led
    low led
    next
    then the same only reversed
    also
    I have seached two books but I cant find what dirs means
    Default Re: Help with Hellebuyck reverse flashing led
    What PIC are you using? What PBP and assembler versions? What CONFIGs are you using?
    Oct 2011
    Looks like it's written for the PICAXE to me
    Quote Originally Posted by firsttimer View Post
    symbol led = b0
    pins = %00000000
    dirs = %11111111
    for led = 0 to 7
    high led
    low led
    low led
    next
    also
    Go check out Parralax basic stamp for dirs, they use it, ME Labs PBP does not.
    Use instead TRIS and flip all the bits from what dirs says.
    edit:
    Ok looking at Chuck's book it appears that PBC does indeed use dirs, I have never used PBC and I do not believe it is still available, but might be wrong in that belief. If you and I have the same book then this is Project 1 and the chip is a 16F876.
    Go to the next page and use the P Basic Pro code listed, it should work.
    Dec 2013
    Thanks the next page version worked ok.
  1. Replies: 3
    Last Post: - 9th June 2012, 16:34
  2. Getting started with Chuck Hellebuyck
    By quester in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 21:10
  3. Getting started with Chuck Hellebuyck fuses
    Last Post: - 9th March 2008, 04:47
  4. Flashing!! LED Dot matrix problem
    Last Post: - 4th December 2006, 10:45
  5. flashing a led with TMR0
    By ely in forum mel PIC BASIC Pro
    Last Post: - 21st June 2004, 22:41
