Re: Help with Hellebuyck reverse flashing led
Originally Posted by
firsttimer
This is what is in his book but it will not programme
symbol led = b0
pins = %00000000
dirs = %11111111
for led = 0 to 7
high led
low led
low led
next
then the same only reversed
also
I have seached two books but I cant find what dirs means
Go check out Parralax basic stamp for dirs, they use it, ME Labs PBP does not.
Use instead TRIS and flip all the bits from what dirs says.
edit:
Ok looking at Chuck's book it appears that PBC does indeed use dirs, I have never used PBC and I do not believe it is still available, but might be wrong in that belief. If you and I have the same book then this is Project 1 and the chip is a 16F876.
Go to the next page and use the P Basic Pro code listed, it should work.
