HEX2 statement result to variable?
Results 1 to 3 of 3
    Default HEX2 statement result to variable?
    Hello.
    I have the code:
    lcdout $FE,$C0,"Hr:",HEX2 hh,":",HEX2 mm
    which works ok
    but when I want to use
    A=HEX2 hh
    it does not works.
    How should I ?
    Default Re: HEX2 statement result to variable?
    How should you what?
    The HEX, DEC, BIN modifiers are used to present the same number in different ways - but it's still the same number. A value of 10 is always 10 but depending on the modifer used it can be displayed as DECimal (10) HEXadecimal (A) or BINary (00001010) but again it's still the same value.
    Lets say hh has the value of 123, what do you expect A to be?
    Yes, so I want to convert a number from BCD to DEC.
    I've already found a solution:
    hh =( hh >> 4 * 10 ) + ( hh // 16 )
    But I thought there should be some statement?
  1. RCTIME not getting a result
    By tasmod in forum mel PIC BASIC Pro
    Last Post: - 13th January 2012, 14:28
  2. XOR result different with PC application
    Last Post: - 26th January 2009, 04:56
  3. Strange LED Result!!
    Last Post: - 18th April 2007, 15:59
  4. RANDOM - always the same result
    Last Post: - 18th March 2007, 12:58
  5. A/D display result on LCD
    By winsthon in forum mel PIC BASIC Pro
    Last Post: - 10th January 2004, 10:09
