18F4550 running 3.3V (serin2) and 16F877 running 5v (serout2), is possible?
Results 1 to 9 of 9
    Dec 2006
    Brasil, Sao Paulo, Campinas
    Default 18F4550 running 3.3V (serin2) and 16F877 running 5v (serout2), is possible?
    Hello all,
    Somebody knows solve it? I have a circuit based on 18f4550 as RX (serin2) using 3,3v as power, and other circuit using 18f877a running 5,0V. I puted a 1k resistor of the TX to the RX pins but sometimes the data fail. I thinnk that is necessary to use some converter. I alread put a divider resistor (15k and 10k without sucess.
    Pimentel
    Dec 2007
    Finland
    Default Re: 18F4550 running 3.3V (serin2) and 16F877 running 5v (serout2), is possible?
    See old Philips I2C application note AN97055, page 10 (Devices with different logic levels connected via the bi-directional level shifter).
    In addition what they propose, you can use e.g BS170, 2N7000, etc...
    May 2008
    Italy
    Two diodes in series will give you a 1.2 volts drop just what you need!
    Cheers
    Al.
    Dec 2007
    Finland
    I was already thinking the next generation version with both way communication (a step ahead)
    2 diodes in series is a good solution!
    Dec 2006
    I tried using 2 diodes (1N4007) but did not work. I also tried to use signal diode 1N4148 but failed. Finally tried with two fast diodes (schotky) and did not work!
    For now the best way of functioning was linking directly (1k resistor between tx(5v) and rx (3,3v) but I know this is wrong and yet sometimes fails!
    Anyone have any more ideas?
    Dec 2007
    Finland
    Sounds that you may have other problems than signal line and components between two PICs.
    - Power supply and de-couplings (internal noise)?
    - External noise coupling (shielding to transmission path between PICs)?
    - Grounding of PICs (GND references)?
    - Grounding between PICs (GDN reference)?
    - Used TX speed (signal integrity)?
    - etc...
  1. 18f4550 running slow?
    By Giulio in forum mel PIC BASIC Pro
    Last Post: - 22nd October 2012, 22:28
  2. 18f4550 running slow?
    Last Post: - 14th October 2012, 23:48
  3. 18F4550 not running
    By comwarrior in forum General
    Last Post: - 1st January 2011, 02:07
  4. running of page warning and error 16f877
    Last Post: - 7th November 2007, 02:05
