Assembler problem
Results 1 to 4 of 4
    Sep 2005
    Campbell, CA
    Default Assembler problem
    I'm having a strange problem when using PBP on my new laptop. I'm away from home now, and don't have access to all my resources.
    I can compile using PBP (3.x) just fine.
    When I try to use the -n option for PBPL, the compile goes OK, but when it gets to the assembler I get the following:
    Name:  Screen Print.jpg
    What is setup improperly on my laptop?
    Charles Linquist
    Default Re: Assembler problem
    Hi Charles,
    I hope I understood the question . . . In MCS Click View, click compile & program options, in there the first check box should be checked . . . Use compiler long words. HTH
    JS
    Scroll down through the list of errors.
    Look for one that says "WARNING: Unable to open INCLUDE file ..."
    I'm guessing you don't have DT_INT-18 on that computer.
    http://darreltaylor.com/DT_INTS-18/home.html
    Or, post the complete list of errors.
    Tried it here without DT_INTS and it gives the warnings at the compiler level, not the ASM.
    So you'll need to post the complete error list.
  1. Assembler problem
    By om3bc in forum mel PIC BASIC Pro
    Last Post: - 25th March 2008, 20:12
  2. which Assembler
    By debutpic in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 00:43
  3. Assembler and interrupt problem
    By milanche in forum mel PIC BASIC Pro
    Last Post: - 21st September 2006, 18:24
  4. Which assembler are you using?
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 1st November 2005, 21:34
  5. Assembler information
    By Demon in forum Documentation
    Last Post: - 25th February 2005, 15:18
