Driving a 2x16 LCD with only One Pin and 74HC595
Results 1 to 21 of 21
    Jan 2014
    Default Re: Driving a 2x16 LCD with only One Pin and 74HC595
    Awesome, Darrel
    Yes, that's it!!
    Can I also write:
    B = Char
    B = B << 4
    I tested it once more with the Pauseus...it also runs.
    Would you still recommend to use the DelayUS Command in whole code?
    Thanks in advance!
    Most definitely, you must not use PAUSEUS.
    And no, you cant use B = B << 4
    The CPU can only shift one bit at a time. So it requires a loop and a variable to count the number of shifts.
    That uses a SYSTEM variable.
    And there are two more issues that cause instability.
    1) The reason I had to change the capacitors is the @ NOP which changes timing with different oscillator frequencies.
    It should be replaced with ...
    @ DelayUS 1
    And the capacitors should be left at 4.7nF
    That way it will work with all PBP OSC frequencies.
    2) And this statement also affects System variables, for the same reason as B =B << 4 ...
    D = B >> E
    It could be replaced with ...
    F  var byte
    G  var byte
    ;D = B >> E
    F = E
    G = B
    ShiftLoop
        G = G >> 1
        F = F - 1
    IF F != 0 THEN ShiftLoop
    D = G.0
    Although I have a feeling it can be reduced somehow.
    I think that should give a stable include file.
    At least it works well here.
    But I'll add that you are using common variable names in the include like ...A, B, C etc.
    That means that when someone uses your include, they cannot use those variable names.
    It's better to make unique variable names that are unlikely to be used by the person using your code.
    Descriptive names are the best. Try to use a name that describes what the variable is used for.
  1. 2x16 LCD Graphics :)
    By Art in forum General
    Last Post: - 13th June 2015, 12:02
  2. Need advice with LCD 2x16
    Last Post: - 26th April 2011, 07:58
  3. LCD via 74HC595
    By helloo in forum General
    Last Post: - 31st October 2010, 21:49
  4. 2x16 lcd problem
    By k3v1nP in forum mel PIC BASIC
    Last Post: - 30th October 2008, 05:46
  5. small 2X16 LCD
    By Ron Marcus in forum Off Topic
    Last Post: - 26th October 2007, 21:37
