Debugging USART using Saleae logic probe
Results 1 to 15 of 15
    Default Debugging USART using Saleae logic probe
    A simple way of viewing USART transmissions when you're already using a Saleae probe.
    HSEROUT [DEC5 varTimer1, DEC5 varTimer3]
    Activate the serial analyser at the bottom right of the Saleae window.
    Name:  Saleae USART analyser.JPG
    In this example, 2 values are displayed at the top of channel 0. Yes, I'm embarassed to admit I just noticed this feature.
    Nov 2007
    West Covina, CA
    Default Re: Debugging USART using Saleae logic probe
    Embarrassed? I think it's exciting to find new tools and uses!
    How do you like your Saleae? I think it's money very well invested and has saved me so much time and headaches especially when it came to watching DT's interrupts at work.
    Louie
    I love it. I'd prefer the 16, but the basic 8 channel model is more than enough for the hobbyist.
    I have 2 oscilloscopes. I don't use them enough to remember how to calculate the time bases to get hertzes. I take them out whenever I want to test switches and debouncing though.
    I'd love a USB scope, but money is real tight so that's out of the question until I win the lottery.
    Nov 2007
    West Covina, CA
    I thought about the 16 also but couldn't imagine what I would test with all those yet!
    I barely hit 6 while playing around with an accelerometer + gyro, DT's INT's, test points, etc..
    Louie
    I've been doing my testing and research in the kitchen using my laptop this winter; it keeps me closer to the family.
    Problem is my laptop has the wrong sex serial connector so I can't use the same cables I've been using on the desktop PC downstairs. Of course I always forget to buy an adapter and was forced to use an LCD to debug.
    And this is where things got tangled with this project; all my pins are busy except RX1/TX1 which will be used for comms. No problem, I pulled out another breadboard that has an LCD and will display there. Wrong, can't figure out why data isn't sent properly.
    The Saleae confirmed that the message leaves the master just fine so it's 50% solved (picture above). The data is lost as soon as I connect the slave PIC. The sad part is that I had all my breadboards talking together just fine last summer but I'm apparently too dense to figure this one out. Yes, I was using these same PIC models too, argh....
    I spent all afternoon and then some yesterday trying to get these talking.
    Had them working in 5 minutes after posting. LOL
    I gave up and did the equivalent of stopping and asking for directions; I looked at my code from last summer real close and noticed this comment:
    'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    '                   RX must be input or else USART disrupted                   x
    I can't remember where I got this (didn't notice in the manual if it was there), but that was the problem.
    EDIT: Now I remember, it was from the datasheet:
    For all modes of EUSART operation, the TRIS control
    bits corresponding to the RXx/DTx and TXx/CKx pins
    should be set to ‘1’. The EUSART control will
    automatically reconfigure the pin from input to output, as
    needed.
  1. Saleae Logic Probe on sale at microchip.com
    By ScaleRobotics in forum Off Topic
    Last Post: - 27th September 2024, 11:26
  2. Kudos to Saleae for service
    By boroko in forum Adverts
    Last Post: - 19th May 2012, 14:38
  3. Logic Probe Recommendations
    By retepsnikrep in forum Off Topic
    Last Post: - 12th June 2011, 20:35
  4. Replies: 12
    Last Post: - 15th May 2011, 23:06
  5. PH Probe A/D Coverter ?
    By shawn in forum Schematics
    Last Post: - 27th August 2008, 10:44
