ICD Malfunction?
Results 1 to 2 of 2
    Mar 2011
    Los Angeles, California
    Default ICD Malfunction?
    Hi All!
    Okay so I have Microcode Studio Plus v 5.0.0.5 and complier PBPX 3.0.6.4. The PIC being used is an 18F1320. I keep getting an ICD timeout error message and the strange part to me is after an ICD compile and program, programming the PIC with MPLAB IDE 8.91, the pic programs without ICD! That is after you have gone through all the steps to program the PIC and you plug it in to the board and apply power it starts to blink without ICD telling it to! Any ideas?
    ' Name : BLINKXU.pbp
    ' Compiler : PICBASIC PRO Compiler 2.6
    ' Assembler :
    ' Target PIC : PIC18F1320 or similar type
    ' Hardware :
    ' Oscillator : 20MHz external
    ' Keywords : FOR NEXT
    ' Description : PICBASIC PRO program to blink an LED
    Define OSC 20
    define loader_used 1
    ENABLE DEBUG
    Include "Modedefs.bas"
    include "hpwm10L.pbp"
    __CONFIG _CONFIG1H, _HS_OSC_1H & _FSCM_OFF_1H
    __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_8K_2H
    __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _BORV_27_2L
    __CONFIG _CONFIG3H, _MCLRE_OFF_3H
    __CONFIG _CONFIG4L, _DEBUG_OFF_4L & _LVP_ON_4L & _STVR_ON_4L
    __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
    __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
    __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
    __CONFIG _CONFIG7H, _EBTRB_OFF_7H
    ADCON1 = 255
    LED Var PORTB.0 ' Alias PORTB.0 to LED
    LOW led
    LOW LED
    mainloop:
    High LED ' Turn on LED connected to PORTD.0
    Pause 500 ' Delay for .5 seconds
    Low LED ' Turn off LED connected to PORTD.0
    GoTo mainloop ' Go back to loop and blink LED forever
    Thanks, Ed
    Mar 2011
    Default Re: ICD Malfunction?
    Not sure what happened and it works now!
  1. DT Interupts and ICD?
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 14th November 2009, 03:02
  2. icd communication
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 17th July 2008, 16:36
  3. ICD problem
    By JoeK in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 01:51
  4. what is ICD?
    By Mostafa in forum General
    Last Post: - 12th September 2006, 15:30
  5. Icd 2
    By nicjo in forum General
    Last Post: - 6th August 2006, 12:31
