how to setup 7 digit led multiplexer code for running in background?
Results 1 to 6 of 6
    Default Re: how to setup 7 digit led multiplexer code for running in background?
    Thanks, looks interesting!
    I'm doing it backwards. Mainloop turns on leds, start a timer, while timer runs gosub main code, turn off leds when timer over. Start a 2nd timer for off period, gosub main code until over. Rinse and repeat.
    I adjust 2 timers until no more flicker.
    The problem is, when looking at that sample code, I see only the part of code, which runs on interrupt. I have no idea where to insert the "main" code?
    In here:
      IF SecondsChanged = 1 THEN
         SecondsChanged = 0
         LCDOUT $FE,2, DEC Days,"d-",DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds
    GOTO Main
    You check the status of the timer flags to determine if things have changed, then reset them.
  1. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  2. Replies: 2
    Last Post: - 14th July 2008, 23:11
  3. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 06:02
  4. Using a MAX7219 (LED digit multiplexer) with a 16F88
    Last Post: - 11th March 2007, 22:11
