Hi Guys,
It should be pretty straight forward, but I'm at a loss. Trying to use a 16F628A and tried searching online for similar issues, but have been unsuccessful in resolving the matter.
I wrote out a large amount of code. Found that one of the outputs on the PIC wasn't doing what it was suppose to do. To make a long story short, I wrote a small bit of code to test the outputs I wanted to control and it's still not working. I tried programming new chips, and get the same result.
My problem: porta.4 (pin 3) does not want to turn on. It stays low and does not activate to control a transistor. I replaced the transistor (in case it was bad), and get the same result. Can someone tell me what I'm missing.
Tony
Code:#CONFIG __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _LVP_OFF & _CP_OFF & _PWRTE_ON & _MCLRE_OFF & _BOREN_OFF #ENDCONFIG Reset: CMCON = 7 ' Analog comparators off VRCON = 0 ' A/D Voltage reference disabled TRISA = %11000001 ' sets pin as input (1) or output (0) TRISB = %00110011 ' sets pin as input (1) or output (0) PORTA = %00000000 ' sets outputs as high (1) or low (0) PORTB = %00000000 ' sets outputs as high (1) or low (0) ' -----[ Variables ]------------------------------------------------------- rightrelay var porta.1 ' right relay output leftrelay var portb.2 ' left relay output rightfet var porta.4 ' right fet output leftfet var porta.2 ' left fet output high leftrelay high rightrelay action: low leftfet high rightfet pause 500 low rightfet high leftfet pause 500 goto action
