12F683 - basic code not working
Results 1 to 40 of 57
    Oct 2009
    Default Re: 12F683 - basic code not working
    Fit a 1k-2k resistor then verify the operation in steps.
    1) Measure the voltage at the PIC output, it should be either 0 or 5V (or close to it). If it's not then something is wrong.
    2) Measure the voltage at the base of transistor, it should be either 0 or 0.6V (or close to it). If it's not something is wrong.
    3) Measure the voltage at the collector of the transistor, it should be 5V when the transitor is OFF and close to 0 when the transitor is ON.
    If it doesn't work please do the above measurments and report the results.
    Fitted a 1.5K resistor
    1) - Voltage out when the pin goes high = 4.52v
    2) - Base of transistor voltage measured 0.73v
    3) - Voltage at collector when PIC pin was HIGH was 0.03v and 5.01v when PIC pin was LOW
    Still the relay contacts didn't switch.
    Thinking it might be the regulator as I'm using a 200mA version of the 7805 I changed this for a traditional 1 amp version - still no change.
    As the new relays are DIL footprint (16 pin DIL) and I am using sockets, I removed the relays and inserted the pins of the original relay into the contacts on the DIL socket. This relay also has a coil of 68 ohms so would be drawing similar current of around 80mA ? - The contacts changed over just fine. Last test was to attach two wires to the coil and plug this into the DIL socket - still no change, but plugging the coil directly across the 5v switched it hard...
    I'm going to re-breadboard the hardware with the DIL relays and see if it switches OK just to rule out a fault on the stripboard (my eyes are not what they used to be - so I could have a dry joint or short somewhere !) - but I don't hold up much hope as any such issues should of resulted in the same thing happening with the original relay when tested with the stripboard.....
    Oct 2009
    Its now working.
    I removed all the links to the relays apart from the coils - tested and it appeared to energise. I then googled the datasheet for the relays and found that the contacts where wired differently to the other relay (NO / NC then the comm rather then NO / comm / NC) - rewired the stripboard (now quite a mess) and it works (well I get 5v out to the motor when the pic energises the relays )
    Thanks to all who contributed - and I'll note that formula for working out the resistances - Cheers Henrik
    Oct 2009
    Default CCT diagram
    Well for reference and to aid anyone who may stumble across this thread in future here's the circuit diagram and final code (full of comments to explain how it works)
    '*  Name    : Chicken Coop Door Control                         *
    '*  Author  : Malcolm Crabbe                                    *
    '*  Date    : 30th January 2014                                 *
    '*  Notes   : Uses PBP 2.60c                                    *
    '*          : 16F690, int osc 4MHz                              *
    '*          : Program uses RTC  to turn                         *
    '*          : on an electric motor and open a sliding door.     *
    '*          : Door travel controlled by limit switches          *
     __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF
    endasm
    DEFINE  OSC 4
    DEFINE HSER_RCSTA 90h                   'Enable serial port & continuous receive
    DEFINE HSER_TXSTA 24h                   'Enable transmit, BRGH = 1
    DEFINE HSER_SPBRG 25                    '9600 Baud @ 0.16%
    DEFINE HSER_CLROERR 1                   'Clear overflow automatically
    ANSEL  = %00000000                      'Set all pins digital
    ANSELH = %00000000                      'Set all pins digital
    ADCON0 = %00000000                      'AD converter module disabled
    OSCCON = %01100101                      'bit7 not used, bits 6-4 4mhz default, bit3 int osc, bit2 HS stable (ignored - at 4Mhz), bit1 not stable, bit0 int osc used for system clk
    CCP1CON= %00000000                      'Turn off CCP module
    SSPCON = %00001011                      'Ic2 master
    TRISA=%00000111                         'set PORTA as all output apart from RA0, RA1 and RA2( bits 7&8 unimplimented read as 0)
    TRISB=%11110000                         'set PORTB as all input ( bits 0-3 unimplimented read as 0)
    TRISC=%11111111                         'set PORTC as all input (default for POR)
    day             var byte
    RTCMin          var byte		        'RTC Minutes
    RTCHour         var byte	            'RTC Hours
    RTCsec          var byte                'RTC Seconds
    TimeH           var byte                'variable to store Hours
    TimeM           var byte                'variable to store Minutes
    SS              VAR Byte                'variable to store Seconds
    CounterA        var byte	            'General purpose Variable
    CounterB        var byte	            'General purpose Variable
    TempWD          VAR WORD
    Counter1        var word                'used to store the current time as a digit.  Counts minutes from 0000 at midnight
    Char            var byte
    Relay           var PortA.5             'used to activate relay and thus reverse direction
    Motor           var PortA.4             'used to drive the motor
    SW1             VAR PortA.0             'Door open limit switch
    SW2             VAR PortA.1             'Door closed limit switch
    SW3             var PortA.2             'Manual close button
    Tx              var PortB.7             'used for sending time value in testing
    Rx              Var PortB.5             'used for receiveing time value in testing
    SetMN           var byte		        'Used to set time Minutes
    SetHR           var byte	            'Used to set time Hours
    SetSS           var byte                'Used to set time Seconds
    onHR            var byte                'Used to set the Opening time (Hrs)
    onMN            var byte                'Used to set the Opening time (Min)
    Ontime          var word                'On time value in minutes
    RCIF            VAR PIR1.5              'USART receive flag
    GIE             VAR INTCON.7
    RCIF=1
    SCLpin          var PORTB.6             'RTC pin - clk
    SDApin          var PORTB.4             'RTC pin - data
    setHR = 06                              'On powerup time set to 00 Hrs
    setMN = 44                              'On powerup time set to 00 minutes
    onHR = 06
    onMN = 46
    CounterA=SetMN                          'convert initial time to BDC and write it to the DS1307
    Gosub ConvertBCD
    RTCMin=CounterB
    CounterA=SetHR
    Gosub ConvertBCD
    RTCHour=CounterB
    I2Cwrite SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]
    day=0                                  ' set mode to night
    low Motor                              ' set motor to off
    low relay                              ' relay off
    I2CREAD SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]  ; read DS1307 chip
    timeH=(RTCHour>>4)                        'convert the BCD format of the hours register and store in variable timeH
    timeH=(timeH &$03)*10
    timeH=timeH+(RTCHour&$0F)
    timeM=(RTCMin>>4)                         'convert the BCD format of the mins register and store in variable timeM
    timeM=(timeM &$07)*10
    timeM=timeM+(RTCMin&$0F)
    ss=(RTCSec>>4)                            'convert the BCD format of the sec register and store in variable ss
    ss=(ss &$07)*10
    ss=ss+(RTCSec&$0F)
    Counter1 = (TimeH *60)+ TimeM             'take hours and multiply it by 60 then add odd minutes to get the total minutes into counter1
    Ontime = (onHR*60)+onMN
    Hserout["Time: ",#TimeH DIG 1,#TimeH DIG 0,":",#TimeM DIG 1,#TimeM DIG 0,":",#ss DIG 1,#ss DIG 0," Counter = ",#counter1," Ontime = ",#ontime,13,10]
    pause 200
    FOR TempWD = 0 TO 1000
            IF RCIF THEN GOto comms                  ' Check to see if there is communications on the comm port
            PauseUs 1000
    NEXT TempWD
    if counter1 = ontime and SW2=1 then              ' If counter matches on time and A.1 is high then
      high Motor                                     ' Turn on the motor
      high relay                                     ' Energise the relay
    if SW1 = 1 then                                  ' Door open limit switch (A.0) hit and applies 5v to pin
      low Motor                                      ' Stop motor
      low relay                                      ' de-energise relay
    if ontime < counter1 or ontime > counter1 then   ' If the counter is anything other than ontime, turn everything off
      low SW1
      low motor                                      ' Turn on the motor
      low relay                                      ' Relay kept off for reverse polarity of motor
    If SW3 = 1 then
    high motor
    low relay
    Low SW1
    if SW2 = 1 and ontime < counter1 or ontime > counter1 then ' Door closed limit switch hit and applies 5v to pin
    goto Main
    convert:
    CounterA=SetMN
    Gosub ConvertBCD
    RTCMin=CounterB
    CounterA=SetHR
    Gosub ConvertBCD
    RTCHour=CounterB
    comms:
    HSERIN [Char]
    SELECT CASE Char
            CASE "T","t"                            ' set time
    hserout ["Set Time Hour ",10]
    HSERIN [#setHR]
    hserout ["Set Time minutes ",10]
    HSERIN [#setMN]
    gosub convert
            CASE "O","o"
    Hserout["Set Open Time: ",13,10]
    hserout ["Set Hour ",10]
    HSERIN [#onHR]
    hserout ["Set Minutes ",10]
    HSERIN [#onMN]
            CASE "C","c"
            Hserout["Time: ",#TimeH DIG 1,#TimeH DIG 0,":",#TimeM DIG 1,#TimeM DIG 0," Counter = ",#counter1,13,10]
    end select
    goto Main
    ' convert BDC format to decimal
     ConvertBCD:
    	CounterB=CounterA DIG 1                        ' CounterA is the entry variable
    	CounterB=CounterB<<4                           ' CounterB holds the converted BCD result on exit
    	CounterB=CounterB+CounterA DIG 0
    Ok the code may be very basic, could possibly be written tighter and isn't really rocket science, but it works for me. Likewise the choice of transistor in the schematic might of been better, but it's what I had and after the debuging - works with the relays etc.
    I would like to thank all those who contributed to this thread and not only provided the support I needed, but also educated me both in PicBasic Pro and electronic component selection. - Thanks guys
    Disclaimer:
    The usual disclaimer applies, ie I accept no responsibility what-so-ever - anyone uses this code / schematic at their own risk etc etc... lardy dar de dar !! -- (sorry to high on pain killers for tooth ache !!)
    Jan 2007
    Default Re: CCT diagram
    Just for the fun of it, you may consider playing around with the relay and transistor separate from the PIC. There may be some possibility that a base bias resistor between 5k to 10K may actually switch that relay quite nicely. If so, that would put even less current demand on the output of the PIC. In the future if you are browsing a supplier like allelectronics, look for the 2n7000 N-Channel mosfet. It can handle 400mA and won't require any current at all from a PIC, since it is voltage driven. Just a 1 meg bias resistor holding the gate to ground. I bought a surplus box-of-em on ebay a while ago. Enough to last me the rest of my life ;-D
    Great pics my friend!! and a very well done project!!
    Congrats!!
    Duane :-]
  1. 12F683 - Pin1 not working
    Last Post: - 8th February 2014, 18:38
  2. 12F683 Maths and code genius reqd.
    Last Post: - 1st January 2014, 09:44
  3. please help with 12f683 pwm code
    By haidar in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2013, 22:25
  4. Problem converting 12F683 code to 12F1840
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 14th March 2013, 02:55
  5. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 21:44
