Add the following defines on top of your code:
DEFINE ADC_BITS 8
DEFINE ADC_CLOCK 2
DEFINE ADC_SAMPLEUS 50
Cheers
Al.
DEFINE ADC_BITS 8
DEFINE ADC_CLOCK 2
Cheers
Al.
Hi Al,
I've modded the code so I can see what's going on.
The divider made up as the LDR between +5v and GPOI.0, and the 18K between GPIO.0 and GND.Code:ASM __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF endasm TRISIO = %001111 ADCON0 = %10000001 ANSEL = %00110011 DEFINE ADC_BITS 8 DEFINE ADC_SAMPLEUS 50 DEFINE ADC_CLOCK 2 CMCON0=7 Tx var GPIO.5 ADChannel0 var byte GPIO = 0 ' clear all output Pause 50 ' internal oscillator settle time main: adcin 0,adchannel0 ' Read AN0 Serout2 Tx,84, ["val: ",#adchannel0,10] pause 5000 goto main
Compiled the code and loaded it to the chip. Opening the serial tool in Micro-studio I get a value of 1 when the LRD is in ambient light or covered and 2 with the torch shone directly on it.
Ideas ??
As a postscript, i wired a 10K pot between +5v and GND with the wiper to GPIO.0 and got the same results - seems the ADC isn't working
OK I'm going to throw this thing out the window in a moment
I downloaded a sample code from this forum written by Bruce
Code:ASM __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF endasm DEFINE ADC_BITS 10 DEFINE ADC_CLOCK 3 DEFINE ADC_SAMPLEUS 50 number VAR word 'CMCON = 7 ' Comparators off ANSEL = %00000001 ' GPIO.0 A/D in, rest digital ADCON0.7 = 1 ' Right justify for 10-bit GPIO = %00000000 ' Initialize outputs TRISIO = %00000001 ' GPIO.0 = input, rest outputs Tx var GPIO.5 main: adcin 0,number ' Read AN0 Serout2 Tx,84, ["val: ",#number,10] pause 5000 goto main
With the 10K pot wired between the supply with the wiper to GPIO.0 and get readings between 437 and 440 !!!!!!!!!!!!!! - still just three digits between min and max.
I had to rem out the CMCON line - presumably the 12F683 has no comparators, would that be the case.
Hi Malcolm,
Comparator register for this chip is CMCON0 set CMCON0=7 to turn off as per data sheet 8.3
It compiles. You might have to set the CCP1CON to zero too , not sure about that though.
I haven't been following this thread but why do you say presumably the 12F683 has no comparators, would that be the case ?
Why not simply open the datasheet and have a look? Sure enough, the 12F683 DOES have a comparator and it's control register is CMCON0 - which you had got correct in your previous snippets of code but not in the latest one. I'm not saying this is the problem though.
Verify that ALL your grounds/commons are connected, as you move the wiper of the pot measure the voltage right at the PIC, between pins 8 (Vss) and 7 (AN0) to verify that it's not a loose connection or floating ground etc.
OK, I've removed the breadboard connection from the EasyPic5 and configured the board to use the 10K pot on the EasyPic5. I have the USB/Serial breakout board connected to +5v, GND and GPIO.5 and confirmed the communications were OK in the serial monitor window. I've added the correct setting for the comparators (must of removed the 0 at the end of the statement when editing the file- my bad).
Loading the code I can get 0 - 1023 by moving the wiper on the EasyPic5 board, so the chip is reading 0-5v and converting that to a digital value.
I then added back the lines for the motor control, making them GPIO.2 and 4, and hooked up the H-Bridge on the breadboard - I added the trigger of 100 in the line "if number >100 then turn on the motor" and watched what happened when I turned the pot on the easyPic5 board and low and behold, when the value hit 101 the motor came on......
I'm going to pull all the connections off the breadboard and re-check the wiring - seems that the issue is external and not the code. One possible cause could be the resistance / capacitance nature of the breadboard causing the issue ??
Anyway, thanks guys for your comments and input.... as always it's nice to receive assistance and helps with the learning curve
Malcolm
Hi again,
I'm stumped on what's happening when I run the following code, and having gone over it time and time again I might be overlooking the obvious.
I have a motor connected to the H-bridge module that arrived yesterday - making pins 1 high and 2 low makes the motor run one way and reversing which pin is high and low makes the motor run the opposite way. I'm using a separate 9v supply for the motor.
When first turned on, the threshold set means that the code is set to night mode. I then shine a light on the LDR and the motor runs until I connect GPIO.5 to 5v to simulate the door closing the micro-switch at the end of its travel. So far so good. However, if I remove the connection between GPIO.5 and +5v to simulate the door in the close state GPIO.5 remains latched high. Grounding the pin momentarily has no affect, and disconnecting the H-bridge has no affect. Only way to clear this is to turn off and on the EasyPic5 board.
The logic behind this project is that when the light level increases at dawn past the threshold it drives the motor which by use of a threaded rod slides open the door on the coop. When the door closes a micro-switch at the end of the travel the power to the motor is turned off and the unit placed in day mode. At the end of the day a switch will be pressed directly applying 5v to pin2 of the H-Bridge thus reversing the motor, opening the door and opening the switch, changing its state from 1 to 0.Code:ASM __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF endasm DEFINE ADC_BITS 10 ' ADC resolution DEFINE ADC_CLOCK 3 DEFINE ADC_SAMPLEUS 50 number VAR word ' Variable to store ADC result day var byte ' Variable to indicate day or night CMCON0=7 CCP1CON=0 ANSEL = %00000001 ' GPIO.0 A/D in, rest digital ADCON0.7 = 1 ' Right justify for 10-bit GPIO = %00000000 ' Initialize outputs TRISIO = %101011 ' GPIO 0,1,3,5 = input, 2 & 4 outputs Motor1 var gpio.2 ' H-Bridge pin 1 Motor2 var gpio.4 ' H-Bridge pin 2 SW1 VAR gpio.5 ' Door open limit switch low sw1 ' Ensure limit switch is 0 (door is closed) low Motor1 ' Turn off H-Bridge pin 1 low Motor2 ' Turn off H-Bridge pin 2 day=0 ' Initialise unit to check if day time main: if sw1=0 then day = 0 ' If limit switch is open, and mode is night then adcin 0,number ' Read AN0 if day=0 then ' Day 0 = night, Day 1 = Day If number >660 then ' If ACD result is above a threshold low SW1 ' Set state of limit switch to off high Motor1 ' Turn on H-Bridge pin 1 Low Motor2 ' Turn off H-Bridge pin 2 endif endif if SW1 = 1 then ' Door closes limit switch and applies 5v to GPIO.5 low Motor1 ' Turn off H-Bridge pin 1 } Stop motor low Motor2 ' Turn off H-Bridge pin 2 } day = 1 ' Set variable to day to indicate the door is open endif goto main
Any ideas ??
Malcolm
