12F683 - basic code not working
Results 1 to 40 of 57
    Oct 2009
    Default Re: 12F683 - basic code not working
    Al,
    My fault, I drew the schematic the wrong way round (I was rushing ). I've now placed diodes between the collector and emitters of each transistor as suggested.
    Measuring the LDR I get a few hundred ohms when the torch is directly into the face of the LDR and around 2.1m ohms when I place my finger over it. Under the ambient light in the room it was averaging 16K - 18K. I've tried placing the LDR and an 18k resistor in series between +ve and GND and then connecting GPOI.0 to the junction between the two. The LED on the development board was lit quite bright and covering the LDR had no effect. I then used a 200 ohm resistor based on the fact that in light the resistance was a few hundred ohms when tested.
    With the 200 ohm resistor in place as a voltage divider with the LDR, under normal room light with a value of adchannel0 >2 in the if then statement the motor runs. If I change that to adchannel0 >3 and re-compile the motor won't run regardless of bright light or darkness.
    With the divider made up as the LDR between +5v and GPOI.0, and the 18K between GPIO.0 and GND I get 0.6v on GPIO.0 when the ldr is covered, and around 3.5v with the torch shone directly at the ldr. So I would assume this voltage range of 3v should be enough for the ADC to read ? so why is it that the ADC is acting more like a switch with a value of 1 rather than 255 steps ?
    May 2008
    Italy
    Add the following defines on top of your code:
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 2
    DEFINE ADC_SAMPLEUS 50
    Cheers
    Al.
    Oct 2009
    Hi Al,
    I've modded the code so I can see what's going on.
     __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF
    endasm
    TRISIO = %001111
    ADCON0 = %10000001
    ANSEL = %00110011
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 2
    CMCON0=7
    Tx              var GPIO.5
    ADChannel0 var byte
    GPIO = 0 ' clear all output
    Pause 50 ' internal oscillator settle time
    adcin 0,adchannel0 ' Read AN0
    Serout2 Tx,84, ["val: ",#adchannel0,10]
    pause 5000
    The divider made up as the LDR between +5v and GPOI.0, and the 18K between GPIO.0 and GND.
    Compiled the code and loaded it to the chip. Opening the serial tool in Micro-studio I get a value of 1 when the LRD is in ambient light or covered and 2 with the torch shone directly on it.
    Ideas ??
    Oct 2009
    As a postscript, i wired a 10K pot between +5v and GND with the wiper to GPIO.0 and got the same results - seems the ADC isn't working
    Oct 2009
    OK I'm going to throw this thing out the window in a moment
    I downloaded a sample code from this forum written by Bruce
    endasm
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    number VAR word
    'CMCON = 7 ' Comparators off
    ANSEL = %00000001 ' GPIO.0 A/D in, rest digital
    ADCON0.7 = 1 ' Right justify for 10-bit
    GPIO = %00000000 ' Initialize outputs
    TRISIO = %00000001 ' GPIO.0 = input, rest outputs
    Tx              var GPIO.5
    adcin 0,number ' Read AN0
    Serout2 Tx,84, ["val: ",#number,10]
    pause 5000
    With the 10K pot wired between the supply with the wiper to GPIO.0 and get readings between 437 and 440 !!!!!!!!!!!!!! - still just three digits between min and max.
    I had to rem out the CMCON line - presumably the 12F683 has no comparators, would that be the case.
    Hi Malcolm,
    Comparator register for this chip is CMCON0 set CMCON0=7 to turn off as per data sheet 8.3
    It compiles. You might have to set the CCP1CON to zero too , not sure about that though.
    I haven't been following this thread but why do you say presumably the 12F683 has no comparators, would that be the case ?
    Why not simply open the datasheet and have a look? Sure enough, the 12F683 DOES have a comparator and it's control register is CMCON0 - which you had got correct in your previous snippets of code but not in the latest one. I'm not saying this is the problem though.
    Verify that ALL your grounds/commons are connected, as you move the wiper of the pot measure the voltage right at the PIC, between pins 8 (Vss) and 7 (AN0) to verify that it's not a loose connection or floating ground etc.
    Oct 2009
    OK, I've removed the breadboard connection from the EasyPic5 and configured the board to use the 10K pot on the EasyPic5. I have the USB/Serial breakout board connected to +5v, GND and GPIO.5 and confirmed the communications were OK in the serial monitor window. I've added the correct setting for the comparators (must of removed the 0 at the end of the statement when editing the file- my bad ).
    Loading the code I can get 0 - 1023 by moving the wiper on the EasyPic5 board, so the chip is reading 0-5v and converting that to a digital value.
    I then added back the lines for the motor control, making them GPIO.2 and 4, and hooked up the H-Bridge on the breadboard - I added the trigger of 100 in the line "if number >100 then turn on the motor" and watched what happened when I turned the pot on the easyPic5 board and low and behold, when the value hit 101 the motor came on......
    I'm going to pull all the connections off the breadboard and re-check the wiring - seems that the issue is external and not the code. One possible cause could be the resistance / capacitance nature of the breadboard causing the issue ??
    Anyway, thanks guys for your comments and input.... as always it's nice to receive assistance and helps with the learning curve
    Malcolm
  1. 12F683 - Pin1 not working
    Last Post: - 8th February 2014, 18:38
  2. 12F683 Maths and code genius reqd.
    Last Post: - 1st January 2014, 09:44
  3. please help with 12f683 pwm code
    By haidar in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2013, 22:25
  4. Problem converting 12F683 code to 12F1840
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 14th March 2013, 02:55
  5. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 21:44
