12F683 - basic code not working
Page 1 of 2 12 LastLast
Results 1 to 40 of 57
    Oct 2009
    Default 12F683 - basic code not working
    Hi Guys,
    Playing about with a 12F863 chip for a small project, but to start with thought I would do the basic LEDs flash to ensure programming and that the PIC runs. The code compiled, and ran, flashing the LED on RA0 (on the EasyPIC5 board, which corresponds to GPIO.0). I then added a simple "if then" statement so that if a switch was pressed taking GPIO.1 low the code would jump to the section to flash the LED. But when compiled and loaded to the chip the LED still continues to flash regardless if the switch is pressed or not. I've enabled the pull up on the development board which has no effect
     __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF
    endasm
    TRISIO = %11111110
    ANSEL = 0
    GPIO.0 = 0
    CMCON0=7
    Motor var GPIO.0
    Switch1 var GPIO.1
    Switch2 var GPIO.2
    If Switch1 = 0 then
    goto demo
    demo:
    high Motor
    low Motor
    Goto main
    Any ideas why ?
    Oct 2009
    Default Re: 12F683 - basic code not working
    Interestingly this works
    endasm
    TRISIO = %11111110
    ANSEL = 0
    GPIO.0 = 0
    CMCON0=7
    Motor var GPIO.0
    Switch1 var GPIO.1
    Switch2 var GPIO.2
    If Switch1 = 1 then
    gosub demo
    demo:
    high Motor
    low Motor
    REturn
    Hi, Malc
    I would have written ...
    endasm
    TRISIO = %00111110
    ANSEL = 0
    GPIO.0 = 0
    CMCON0=7
    Motor var GPIO.0
    Switch1 var GPIO.1
    Switch2 var GPIO.2
    If !Switch1 then
    demo:
      high Motor
      low Motor
    but it's just me ...
    at least, your "endif" should be placed just before the " demo " label ...
    cause the " IF " condition never sees the " ENDIF " condition reset ....
    tadaaaaaa ...
    Sep 2010
    Las Vegas, NV
    I'm assuming your using PBP3 and to do configs you need to do them like this and both "config" lines need to be in caps. I know PBP2.6 was different but with either version both "config" lines need to be in caps.
    ;configuration directives in Assembly Language
    TRISIO on the 12F683 is only 6 bits wide so I'm wondering if you need to change it to TRISIO = %111110. I think when you set the TRISIO and the GPIO as input and low respectively you'll always have a low at GPIO.0. When you set the pin low and told it to wait for a low it did what you told it to do. That is go to the demo subroutine. Since you changed it to =1 you had a state change and the chip could sense that. The reply by Acetronics2 did that by using the ! sign.
    Your second take on the subroutine and endif look better.
    As usual I'll await for someone to tell I'm wrong.
    Oct 2009
    Quote Originally Posted by AvionicsMaster1 View Post
    I'm assuming your using PBP3 .
    Sorry, wrong assumption - using 2.60
    Quick question and slightly off topic, but related to this project... I'm using an H-bridge to control the motor as I need it to be bi-directional. I've been experimenting with some NPN and PNP transistors that I had in my hobby box, BC639 and BC640 and have had a small low current motor running from the PIC. However the actual motor I will be using is a 540 type with a 6:1 gearing. Even though it will be running from a 3v supply (separate to the 5v pic supply) my guess is that the current might be too high for the BC639 / 640 transistors. Can anyone advise if using these transistors would be OK for such a motor, or should I use something like the TIP220 transistors ??
    Dec 2012
    Tennessee
    I would use FET's, or a L298 chip. the 298 works great. the FET's i use are a bit overkill for what your doing but you can get lower values.
    some that work well for all hobby motors from the old style that were in tape decks to modern RC racecars is
    RFP12N10L
    IRF540
    IRF9530
    Chris
    Any man who has accomplished anything in electronics at one time or another has said... " STOP! WAIT! NOOO! Dangit.... Oh Well, Time to start over..."
    Oct 2009
    Following suggestions I've ordered a module from e-bay based on an L298N controller, which should work as under testing the 540 motor was drawing 0.7A and these things are rated at 2A.
    I'm now working on the light detection side of the circuit. Basically the idea is to automatically open a door at dawn (wife now keeps chickens !). So when the light level reaches or exceeds a threshold, the motor runs, opening the door until the door hits a micro switch which then changes a pin status which then turns off the motor.
    I've purchased a 16k-33K LDR from Maplin ( http://www.maplin.co.uk/p/16k-33k-oh...resistor-n57ay ) and connected that from the 5v line to GPIO.0 and covering the LDR makes the associated LED on my development board go out, and increase in brightness due to ambient light or when a bright torch is shon on the LDR. So the resistance is varying based on the light level, so far so good. Now the issue I'm having is that having set the ACD to 8 bits this should give me a 0 - 254 range of values... but in testing to get the motor to run at various values, these are not what I would expect.
    Here's the test code:
    endasm
    ' Hardware configuration
    TRISIO = %001111
    ADCON0 = %10000001
    ANSEL = %00110011
    DEFINE ADC_BITS 8
    DEFINE ADC_SAMPLEUS 50
    CMCON0=7
    Motor1 var GPIO.4
    Motor2 var GPIO.5
    ADChannel0 var word
    GPIO = 0 ' clear all output
    Pause 50 ' internal oscillator settle time
    low Motor1
    low Motor2
    adcin 0,adchannel0 ' Read AN0
    If adchannel0 >2 then
      high Motor1
      Low Motor2
      pause 5000
    low Motor1
    low Motor2
    If I put in <1 for the argument, the motor runs even with the LDR covered. If I put in >1 the motor won't run unless I shine the torch directly on the LDR. I'm sitting here in ambient light with the sun shining in the window so the motor should be running.
    Any ideas as to what I'm doing wrong ?
    Do you use a word for 8 bit as well?
    Motor2 is never going on by the way.
    Oct 2009
    OK corrected that (original example code must of been for higher resolution...) but still no joy in setting the thresholds
    Motor two is always off in this example as its the other terminal to the H bridge
    May 2008
    Italy
    You should post the schematic of your project in order to get proper help. Very likely your problem is in the hardware arrangement.
    Cheers
    Al.
    Oct 2009
    Al,
    The PIC is on an EasyPIC5 development board, but basically this is the schematic. I've also tried replacing the LDR with a 10k pot and whilst the LED on the dev board dims in brightness the threshold values still have the same effect. Placing the LDR between +5 and GPIO.0 gives a better range of brightness in the LED (not shown in the schematic) from off when the LDR is covered, to bright when an LED torch is placed directly over the LDR.
    I don't program much, so often feel like a newbie when I dust off the development board, and ADC is something I've only once played with. As far as I can understand, the voltage on GPIO.0 should be converted into a byte value between 0 and 254, so I could set the threshold at which point GPIO.4 is made high ?
    Shouldn't there be protective diodes "somewhere" whenever a motor is used?
    I don't really get how that motor is wired. I would expect a pulse method, but the code is constant on for 5 seconds.
    Admittedly confused.
    Oct 2009
    Robert,
    I grabbed the h-bridge circuit from a web site, which using pnp / npn transistors works ok for the test motor (see above). I will be using an H-bridge chip for the larger motor.
    Yes for testing I have the motor running for 5 sec once the threshold has been breached
    Sep 2010
    Las Vegas, NV
    I think you need a voltage divider network for the LDR. As it is the voltage on your ADC input line will always be 5VDC.
    I also wonder about the capacity of your transistors. The stall current on the some of the motors I found was 46 Amps. If the motor were to stall, your transistors would burn out with unknown consequences. If you want to use this motor I'd put a fuse in the supply line to limit current during stalls.
    Typically motors make alotta noise when running. I think it's a great idea to separate the power supplies. Just make sure to make the low side connected between the two systems.
    My intimation of TRISIO is relevant to PBP2.6 also. I'm not sure if PBP starts with LSB when reading the TRISIO and quits after 6 bits or starts at the MSB and quits after 6 bits. I do know the 12F683 only has 5 I/O pins and one I only pin so your TRISIO statement should be 6 bits wide.
    Oct 2009
    Thanks for the comments:
    I've tried using the LDR in series with a 10K pot between 5v and GND, connecting GPOI.0 to the junction between them and still can't get anything meaningful for the value of the variable that stores the ADC readings.
    I've corrected the code thus:
    endasm
    TRISIO = %001111
    ADCON0 = %10000001
    ANSEL = %00110011
    DEFINE ADC_BITS 8
    CMCON0=7
    Motor1 var GPIO.4
    Motor2 var GPIO.5
    ADChannel0 var byte
    low Motor1
    low Motor2
    If adchannel0 >10 then
      high Motor1
      Low Motor2
    pause 5000
    low Motor1
    low Motor2
    May 2008
    Italy
    Check the risistence of your LDR in both condition (dark and light). Since the lowest resistance should be found in light, use this value for your devider network. In this way you should have a value in volts near to zero in dark and near to Vdd/2 in light, more than enough to be sure to trip the system at the right time.
    By the way the schematics of your Hbridge is wrong! NPN should be connected on the low side, while PNP should be connected on the high side.
    Follow the wise suggestion given above, always use freewheel diodes when using inductors!
    Cheers
    Al.
    Oct 2009
    Al,
    My fault, I drew the schematic the wrong way round (I was rushing ). I've now placed diodes between the collector and emitters of each transistor as suggested.
    Measuring the LDR I get a few hundred ohms when the torch is directly into the face of the LDR and around 2.1m ohms when I place my finger over it. Under the ambient light in the room it was averaging 16K - 18K. I've tried placing the LDR and an 18k resistor in series between +ve and GND and then connecting GPOI.0 to the junction between the two. The LED on the development board was lit quite bright and covering the LDR had no effect. I then used a 200 ohm resistor based on the fact that in light the resistance was a few hundred ohms when tested.
    With the 200 ohm resistor in place as a voltage divider with the LDR, under normal room light with a value of adchannel0 >2 in the if then statement the motor runs. If I change that to adchannel0 >3 and re-compile the motor won't run regardless of bright light or darkness.
    With the divider made up as the LDR between +5v and GPOI.0, and the 18K between GPIO.0 and GND I get 0.6v on GPIO.0 when the ldr is covered, and around 3.5v with the torch shone directly at the ldr. So I would assume this voltage range of 3v should be enough for the ADC to read ? so why is it that the ADC is acting more like a switch with a value of 1 rather than 255 steps ?
    May 2008
    Italy
    Add the following defines on top of your code:
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 2
    Cheers
    Al.
    Oct 2009
    Hi Al,
    I've modded the code so I can see what's going on.
    endasm
    TRISIO = %001111
    ADCON0 = %10000001
    ANSEL = %00110011
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 2
    CMCON0=7
    Tx              var GPIO.5
    ADChannel0 var byte
    Serout2 Tx,84, ["val: ",#adchannel0,10]
    pause 5000
    The divider made up as the LDR between +5v and GPOI.0, and the 18K between GPIO.0 and GND.
    Compiled the code and loaded it to the chip. Opening the serial tool in Micro-studio I get a value of 1 when the LRD is in ambient light or covered and 2 with the torch shone directly on it.
    Ideas ??
    Oct 2009
    As a postscript, i wired a 10K pot between +5v and GND with the wiper to GPIO.0 and got the same results - seems the ADC isn't working
    Oct 2009
    OK I'm going to throw this thing out the window in a moment
    I downloaded a sample code from this forum written by Bruce
    endasm
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    number VAR word
    'CMCON = 7 ' Comparators off
    ANSEL = %00000001 ' GPIO.0 A/D in, rest digital
    ADCON0.7 = 1 ' Right justify for 10-bit
    GPIO = %00000000 ' Initialize outputs
    TRISIO = %00000001 ' GPIO.0 = input, rest outputs
    Tx              var GPIO.5
    adcin 0,number ' Read AN0
    Serout2 Tx,84, ["val: ",#number,10]
    pause 5000
    With the 10K pot wired between the supply with the wiper to GPIO.0 and get readings between 437 and 440 !!!!!!!!!!!!!! - still just three digits between min and max.
    I had to rem out the CMCON line - presumably the 12F683 has no comparators, would that be the case.
    Hi Malcolm,
    Comparator register for this chip is CMCON0 set CMCON0=7 to turn off as per data sheet 8.3
    It compiles. You might have to set the CCP1CON to zero too , not sure about that though.
    I haven't been following this thread but why do you say presumably the 12F683 has no comparators, would that be the case ?
    Why not simply open the datasheet and have a look? Sure enough, the 12F683 DOES have a comparator and it's control register is CMCON0 - which you had got correct in your previous snippets of code but not in the latest one. I'm not saying this is the problem though.
    Verify that ALL your grounds/commons are connected, as you move the wiper of the pot measure the voltage right at the PIC, between pins 8 (Vss) and 7 (AN0) to verify that it's not a loose connection or floating ground etc.
    Oct 2009
    OK, I've removed the breadboard connection from the EasyPic5 and configured the board to use the 10K pot on the EasyPic5. I have the USB/Serial breakout board connected to +5v, GND and GPIO.5 and confirmed the communications were OK in the serial monitor window. I've added the correct setting for the comparators (must of removed the 0 at the end of the statement when editing the file- my bad ).
    Loading the code I can get 0 - 1023 by moving the wiper on the EasyPic5 board, so the chip is reading 0-5v and converting that to a digital value.
    I then added back the lines for the motor control, making them GPIO.2 and 4, and hooked up the H-Bridge on the breadboard - I added the trigger of 100 in the line "if number >100 then turn on the motor" and watched what happened when I turned the pot on the easyPic5 board and low and behold, when the value hit 101 the motor came on......
    I'm going to pull all the connections off the breadboard and re-check the wiring - seems that the issue is external and not the code. One possible cause could be the resistance / capacitance nature of the breadboard causing the issue ??
    Anyway, thanks guys for your comments and input.... as always it's nice to receive assistance and helps with the learning curve
    Malcolm
    Oct 2009
    Hi again,
    I'm stumped on what's happening when I run the following code, and having gone over it time and time again I might be overlooking the obvious.
    I have a motor connected to the H-bridge module that arrived yesterday - making pins 1 high and 2 low makes the motor run one way and reversing which pin is high and low makes the motor run the opposite way. I'm using a separate 9v supply for the motor.
    When first turned on, the threshold set means that the code is set to night mode. I then shine a light on the LDR and the motor runs until I connect GPIO.5 to 5v to simulate the door closing the micro-switch at the end of its travel. So far so good. However, if I remove the connection between GPIO.5 and +5v to simulate the door in the close state GPIO.5 remains latched high. Grounding the pin momentarily has no affect, and disconnecting the H-bridge has no affect. Only way to clear this is to turn off and on the EasyPic5 board.
    endasm
    DEFINE ADC_BITS 10              ' ADC resolution
    DEFINE ADC_CLOCK 3
    number VAR word                 ' Variable to store ADC result
    day var byte                    ' Variable to indicate day or night
    CMCON0=7
    CCP1CON=0
    TRISIO = %101011                ' GPIO 0,1,3,5 = input, 2 & 4 outputs
    Motor1          var gpio.2      ' H-Bridge pin 1
    Motor2          var gpio.4      ' H-Bridge pin 2
    SW1             VAR gpio.5      ' Door open limit switch
    low sw1                         ' Ensure limit switch is 0 (door is closed)
    low Motor1                      ' Turn off H-Bridge pin 1
    low Motor2                      ' Turn off H-Bridge pin 2
    day=0                           ' Initialise unit to check if day time
    if sw1=0 then day = 0           ' If limit switch is open, and mode is night then
    if day=0 then                   ' Day 0 = night, Day 1 = Day
      If number >660 then           ' If ACD result is above a threshold
      low SW1                       ' Set state of limit switch to off
      high Motor1                   ' Turn on H-Bridge pin 1
      Low Motor2                    ' Turn off H-Bridge pin 2
    if SW1 = 1 then                 ' Door closes limit switch and applies 5v to GPIO.5
      low Motor1                    ' Turn off H-Bridge pin 1 }  Stop motor
      low Motor2                    ' Turn off H-Bridge pin 2 }
      day = 1                       ' Set variable to day to indicate the door is open
    The logic behind this project is that when the light level increases at dawn past the threshold it drives the motor which by use of a threaded rod slides open the door on the coop. When the door closes a micro-switch at the end of the travel the power to the motor is turned off and the unit placed in day mode. At the end of the day a switch will be pressed directly applying 5v to pin2 of the H-Bridge thus reversing the motor, opening the door and opening the switch, changing its state from 1 to 0.
    Any ideas ??
    Malcolm
    First you configure GPIO.5 as an input by setting the TRISIO.5=1 - OK, that's fine since you're going to be monitoring a switch connected to that pin.
    Then you set up an alias so that SW1 accesses GPIO.5 - perfectly fine.
    Then you go and do LOW SW1 - which turns the GPIO.5 into an output and pulls it low - not OK, the pin is no longer an input so it can't read the state of the switch.
    Keep GPIO.5 as an input and make sure it has a pullup resistor to Vcc if the switch pulls it low or a pulldown resistor do Vss if the switch pulls it high.
    Oct 2009
    Cheers Henrik,
    I've removed all reference to SW1 =1 or LOW SW1 and it now no longer latches. - Thank you.
    Now to actually turn this into a working door
    Oct 2009
    Default Re: 12F683 - basic code now working
    I've been playing about with the code and have now tested it on the development board over and over again, simulating the process of the door actuator being manually closed, and then opened triggered by the increasing light levels at dawn. Next step will be to transfer the PIC to a bit of strip board and add the regulators etc and then test it for real and monitor the current drawn to close the door on the coop. I plan on using a motorcycle battery 12v /4Ah which should be plenty. If funds permit I may add solar charging as a project at a later date.
    Anyway, thanks guys for the assistance with this...
    Malc
    Sep 2010
    Las Vegas, NV
    I did a project similar to this and had to account for something blocking door travel. I ended up with .1 ohm, I think, in series with the motor to monitor load by measuring the voltage across the resistor to determine current flow.
    If motor is free running then current will be high initially but should be lower once friction and inertia are overcome. But if it's blocked/hampered/whatever the stall current will stay relatively high. I think I set it up to try to open and if blocked wait some time and then try again. Another ADC input if you've got a free port. Just a thought.
    Oct 2009
    Default Re: 12F683 - basic code now / NOT / working
    Well that version of the project didn't work so well in the field...
    I'm now working on a second version which uses a RTC. Basically I already have half the code written for one of my other projects so most of this will be a cut and paste. But something is really puzzling me and would welcome your advice.
    I'm using a 16F690 (20 pin DIP) because it has both a basic UART and IC2 interface, and I happened to have a sample in my project box. I could be cleaver (yeah right) and use the full capabilities of the DS1307 and program the times for each month so it takes care of BST and GMT etc, but for now I thought the easiest way would be to use a serial utility to set the time and trigger value as required. Using PicMultiCalc to get the coms values I am able to connect and receive data, however the time is shown as 00:00 in the following code. Now like I mentioned , I've cut and pasted the section and same variables in a previous project so there should be no reason for it not to work. To prove the DS1307 is working on the breadboard (it hasn't been removed since I took a break from the previous project) I removed the 16F690 and replaced it with the 18F4580 and connected the jumper to the EasyPIC5 board - clock was displaying the time set by the code. Noted the correct clk and dta pins, powered down the EP5 board and mapped the connections to the pins used by the 16F690. Replaced the 16F690 and tested again - the serial monitor in Microcode Studio connected and displayed "Time : 00:00"
    I've looked at the data sheet, but not sure if I am missing anything (probably some register needs setting but I'll be dammed if I can see it) so hopefully someone here might be able to assist.
    Here's the code
    '*  Name    : Chicken Coop Door Control                         *
    '*  Author  : Malcolm Crabbe                                    *
    '*  Date    : 30th January 2014                                 *
    '*  Notes   : Uses PBP 2.60c                                    *
    '*          : 16F690, int osc 4MHz                              *
    '*          : Program uses RTC  to turn                         *
    '*          : on an electric motor and open a sliding door.     *
    '*          : Door travel controlled by limit switches          *
    endasm
    ANSEL=%00000000
    ADCON1=7
    ADCON0 = %00000000                      'AD converter module disabled
    ADCON1 = %00001111
    TRISA=%00000011                         'set PORTA as all output
    TRISC=%00000001                         'set PORTC as all output apart from RC0
    TRISB=%00000011
    DEFINE HSER_RCSTA 90h                   'Enable serial port & continuous receive
    DEFINE HSER_TXSTA 24h                   'Enable transmit, BRGH = 1
    DEFINE HSER_SPBRG 25                    '9600 Baud @ 0.16%
    DEFINE HSER_CLROERR 1                   'Clear overflow automatically
    day             var byte
    RTCMin          var byte		        'RTC Minutes
    RTCHour         var byte	            'RTC Hours
    RTCsec          var byte                'RTC Seconds
    TimeH           var byte                'variable to store Hours
    TimeM           var byte                'variable to store Minutes
    SS              VAR Byte                'variable to store Seconds
    CounterA        var byte	            'General purpose Variable
    CounterB        var byte	            'General purpose Variable
    Counter1        var word                'used to store the current time as a digit.  Counts minutes from 0000 at midnight (to be added later)
    Relay           var PortA.5             'used to activate relay and thus reverse direction
    Motor           var PortA.4             'used to drive the motor
    SW1             VAR PortA.0             'Door open limit switch
    SW2             VAR PortA.1             'Door closed limit switch
    Tx              var PortB.7             'used for sending time value in testing
    Rx              Var PortB.5             'used for receiving time value in testing
    SetMN           var byte		        'Used to set time Minutes
    SetHR           var byte	            'Used to set time Hours
    SetSS           var byte                'Used to set time Seconds
    RCIF            VAR PIR1.5              'USART receive flag
    GIE             VAR INTCON.7
    RCIF=1
    SCLpin          var PORTB.6             'RTC pin - clk
    SDApin          var PORTB.4             'RTC pin - data
    setHR = 08                              'initial time to 8am
    setMN = 00
    'convert initial time to BDC and write it to the DS1307
    CounterA=SetMN
    Gosub ConvertBCD
    RTCMin=CounterB
    CounterA=SetHR
    Gosub ConvertBCD
    RTCHour=CounterB
    I2Cwrite SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]
    test:
    I2CREAD SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]  ; read DS1307 chip
    timeH=(RTCHour>>4)                        'convert the BCD format of the hours register and store in variable timeH
    timeH=(timeH &$03)*10
    timeH=timeH+(RTCHour&$0F)
    timeM=(RTCMin>>4)                         'convert the BCD format of the mins register and store in variable timeM
    timeM=(timeM &$07)*10
    timeM=timeM+(RTCMin&$0F)
    ss=(RTCSec>>4)                            'convert the BCD format of the sec register and store in variable ss
    ss=(ss &$07)*10
    ss=ss+(RTCSec&$0F)
    Counter1 = (TimeH *60)+ TimeM             'take hours and multiply it by 60 then add odd minutes to get the total minutes into counter1
    Hserout["Time: ",#TimeH DIG 1,#TimeH DIG 0,":",#TimeM DIG 1,#TimeM DIG 0,10]
    goto test
    ' convert BDC format to decimal
     ConvertBCD:
    	CounterB=CounterA DIG 1                        ' CounterA is the entry variable
    	CounterB=CounterB<<4                           ' CounterB holds the converted BCD result on exit
    	CounterB=CounterB+CounterA DIG 0
    Sep 2010
    Las Vegas, NV
    Well, just the first part of the post I'm not sure what state you want ADCON1 set to. Initially you have it set to 7 then 15. That one extra bit appears to significantly effect your ADC conversion cycle.
    I also think you need to set OSCCON and put a DEFINE OSC ? in your code. I know the default is 4MHz but isn't the RC oscillator in your config the low low frequency oscillator? Could be wrong about that without reading further.
    TRISA is only 6 ports and I think PBP starts with the LSB so you'll have bits 0 and 1 as input. TRISB doesn't look to have RB0 to RB3 so only 4 bits needed to set as output. TRISIC is indeed 8 bits but you've got TRISIC.0 set to input not as described in comments.
    I don't often do serial so you'll have to let someone else chime in. I didn't look at rest of code. Hopefully I'm correct on at least one of these items and it will solve your problem.
    Oct 2009
    Thanks for the assistance
    I've just sat down with a large mug of coffee and some toast and run through the datasheet... I think I've covered most things (I still find these datasheets a struggle, but hopefully picking things up). I've set the registers as follows (with comments), and the code compiles
    endasm
    DEFINE  OSC 4
    ANSEL  = %00000000                      'Set all pins digital
    ANSELH = %00000000                      'Set all pins digital
    OSCCON = %01100101                      'bit7 not used, bits 6-4 4mhz default, bit3 int osc, bit2 HS stable (ignored - at 4Mhz), bit1 not stable, bit0 int osc used for system clk
    CCP1CON= %00000000                      'Turn off CCP module
    SSPCON = %00001011                      'Ic2 master
    TRISA=%00000011                         'set PORTA as all output apart from RA0 and RA1( bits 7&8 unimplimented read as 0)
    TRISB=%11110000                         'set PORTB as all input ( bits 0-3 unimplimented read as 0)
    TRISC=%11111111                         'set PORTC as all input (default for POR)
    Having compiled and loaded the code, pleased to say it all works now !!
    OK I might of gone overboard on configuring registers, but at least it's helped me get some understanding with the datasheets.
    Glad you've got it going! Just a quick note: The I2CREAD/I2CWRITE commands does not use the (M)SSP module in the PIC. You're enabling the (M)SSP module for I2C mode so I'm actually a bit surprised that it works because I thought that when enabled it (the (M)SSP module) takes control over the I/O-pins - I'm obviously mistaken there.
    However, the PBP I2C commands are bitbanged, they don't use the I2C hardware in the PIC so there's no need to enable the hardware for it. It might lead to problems.
    Oct 2009
    Thanks Henrik,
    So I can remove the SSPCON line ?
    Yes, according to the datasheet the POR default of the SSPCON register is 0. Looking at the register definition it shows that as long as bit 5 is 0 the SSP module is disabled and its pins functions as normal I/O. This is probably also why it works the way you currently have it - you do have it configured for I2C mode but it's not actually enabled since bit 5 is cleared. Had you enabled it I don't think the I2C commands would've worked since the SSP module then would've been in control of the pins.
    Oct 2009
    Default Re: 16F690 - code working - brain freeze on schematic !!!
    Guys,
    I've been resting my code using a DC motor driven by a simple transistor circuit as per attached which works well, with the intention of using a double pole change over relay to switch the polarity to the motor (throw off from my old model railway days as that's how we used to make the loco go backwards or forwards). The think is I can't get my head round how to use the transistor to turn the power on / off.
    I came up with the attached, but not sure if this would work, or if I should have the transistor between the relay and GND (ie C to relay, E to GND). I've left the Diode out as the motor is bi-directional
    Advice welcome before I blow up a handful of transistors trying
    Sep 2009
    I use this for motor driver:
    Oct 2009
    Thanks you..
    Regarding your first schematic, generally you need to put the transistor on the low side. Otherwise you need a higher voltage on the base than you've got on the collector. Put the relay "on top", then on to the motor and finally the transistor at the bottom, emitter to ground. Yes, the motor is biderectional but the current thru the transistor is always the same so put the diode back across is, cathode facing "up" of course.
    Oct 2009
    Quick questions guys, I've been developing the hardware further and need to swap the 2930 transistor for something more powerful for driving the 540 type motor. I have a TIP126 PNP darlington, which works, but with reverse logic on the base. IE instead of turning on when the base is high it's high when the pic pin is low. I could change the code so that the output is constantly high and goes low when the conditions are met, but was wondering if there was a simple way of making the transistor fire with a positive voltage on its base ?
  1. 12F683 - Pin1 not working
    Last Post: - 8th February 2014, 17:38
  2. 12F683 Maths and code genius reqd.
    Last Post: - 1st January 2014, 08:44
  3. please help with 12f683 pwm code
    By haidar in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2013, 21:25
  4. Problem converting 12F683 code to 12F1840
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 14th March 2013, 01:55
  5. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 20:44
