Help to setup ADC for 16F1826
Results 1 to 6 of 6
    Default Help to setup ADC for 16F1826
    I am pulling what hair is left out of my head.
    For PIC16F1826, I am trying to get the ADC setup.
    I have a voltage INPUT on RA2 (pin1).
    This is where I want to ADC to be controlled (AN2).
    I referred to the datasheet (page 139), but cannot get this thing to work.
    I also have INPUTS on RA3 (pin2) and RA5 (pin4)
    Here is my code:
    '= PIC16F1826                                           =
    'Initialize variable
     __config _CONFIG1, _FOSC_HS & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
     __config _CONFIG2, _PLLEN_OFF & _LVP_OFF & _STVREN_OFF
    '_MCLRE_OFF = MCLR pin functions as INPUT RA5, MCLR internally tied to VDD
    DEFINE ADC_BITS 8       ' 8 bit A/D Conversion
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50   ' 50 uS A/D sample time
    PORTA = 0
    PORTB = 0
    TRISA = %00101100
    TRISB = %00000000
    ADCON0 =%00001001
    ADCON1 =%11000000      'Right justified
    ANSELA =%00000100      ' AN2 on PortA.2 analog
    ANSELB =%00000000      ' Digital inputs
    FVRCON = 0
    DACCON0 = 0
    DACCON1 = 0
    INTCON = 0
    CM1CON1 = 0
    adval var word
    mainloop:
    adcin 2, adval
    if adval<18 then PortB.3 = 1
    if adval>28 then PortB.3 = 0
    goto mainloop
    Help please!!
    Thx!
    Jan 2011
    Sydney, Australia
    Default Re: Help to setup ADC for 16F1826
    Two things I have noticed in your code:
    1/. The 16F1826 has a 10 bit ADC whereas you have defined an 8 bit setup
    2/. ADCCON0 = %00001001 sets the ADC channel to be AN9 where you are trying to use AN2
    Cheers
    Barry
    VK2XBP
    Hey Barry!
    Thanks so much!!!
    This did it!
    DEFINE ADC_BITS 10 ' 10 bit A/D Conversion
    DEFINE ADC_CLOCK 4
    PORTA = 0
    PORTB = 0
    TRISA = %00101100
    TRISB = %00000000
    ANSELA =%00000010 ' AN2 on PortA.2 analog
    I actually thought you could tell a 10-bit ADC to work as an 8-bit. But no worries! All is perfect once again!!
    Oct 2011
    Hi SOTATOSA
    10 bit A/D converters do work in 8 bit mode. Just set LEFT justified and the 8 MSBs are held in the ADRESH register and the 2 LSBs are held in the ADRESL register bits 6 and 7 which you ignore. ADRESH register contains the 8 bit result. I think this is how DEFINE ADC_BITS 8 works. Setting 8 bit conversion AND RIGHT justified would cause some confusion. Hope this helps.
    Phil
    Oct 2009
    Utah, USA
    this tutorial helped me understand A/D a little better...
    http://www.microcontrollerboard.com/...converter.html
    and here is another good tutorial...
    http://www.edaboard.com/nextoldesttoentry1570.html
    Dwight
    Thanks for all the replies. Making some kind of sense now! :-)
  1. ADC problems with a 16F1826 chip
    By alec in forum mel PIC BASIC Pro
    Last Post: - 1st September 2012, 23:09
  2. ADC problem on 18F46K22 device using all 28 ADC pins
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2012, 21:22
  3. 16F913 setup
    By Andre_Pretorius in forum General
    Last Post: - 18th April 2010, 00:45
  4. ADC setup for 16F716
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 12th November 2009, 03:39
  5. LCD setup
    By ruijc in forum General
    Last Post: - 19th November 2007, 10:04
