Serin2 and STR Modifier
Results 1 to 5 of 5
    _Ian's Avatar
    _Ian Guest
    Default Serin2 and STR Modifier
    Hi all,
    I have a question about the STR modifier for serin2 (or DEBUGIN, I'm assuming that they act the same way?). Simply put, does STR do any ascii conversion of the input bytes when it writes them to the array? In other words, if I do:
    DEBUGIN [STR array\1]
    and the incoming byte is $44, then
    array[0] == $44
    and not $52, or something else?
    Sample Code:
    This ends with the array full of garbage:
    payload var byte[15]
    reply var byte
    msg var byte
    timeout con byte
    reply = 5
    DEBUGIN timeout, error, [WAIT(msg), STR payload\reply]
    While this one works fine:
    reply var byte
    msg var byte
    timeout con byte
    reply = 5
    DEBUGIN timeout, error, [WAIT(msg), payload[0],_
    payload[1],_
    payload[5] ]
    Other than this, the serial comm works fine, but I can't seem to get STR to do what (I think) it should. I am new to PBP, though...
    Thanks much,
    Ian
    Try it with a constant for the array size rather than a variable...
    DEBUGIN timeout, error, [WAIT(msg), STR payload\5]
    _Ian's Avatar
    _Ian Guest
    Default More DEBUGIN Weirdness...
    Hi Melanie,
    Actually, it doesn't seem to make a difference whether the value for STR is variable or constant.
    Also, SKIP seems to be generating the same issues...If I:
    debugin timeout, error, [wait(msg),_
    tmp,tmp,tmp,_
    tmp,tmp,tmp,_
    tmp,tmp,tmp,_
    tmp,tmp,tmp,_
    tmp,_
    payload[0],_ 'real data starts here
    payload[1],_
    payload[2],_
    payload[3]]
    Then I get the expected bytes in payload. But if I do this:
    debugin timeout, error, [wait(msg), skip 13,_
    payload[0],_
    payload[1],_
    payload[2],_
    payload[3]]
    Then I get four completely different bytes in payload. Moveover, they are not bytes that I can identify in the datastream, either before or after my four "target" bytes. But then, they are not random, either.
    One thing that I did not mention before, I am running at a heck of a baud rate: 115200. My setup code looks like:
    '=====DEFINES===================================== =======
    DEFINE OSC 20
    '======Outputs==================================== =======
    DEFINE DEBUG_PACING 70
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 6
    DEFINE DEBUG_BAUD 115200
    define DEBUG_MODE 1 'inverted
    '======Inputs===================================== =======
    DEFINE DEBUGIN_PACING 70 '(8 / BAUD) * 10^6 us
    DEFINE DEBUGIN_REG PORTB
    DEFINE DEBUGIN_BIT 7
    define DEBUGIN_MODE 1 'inverted
    Am I doing something really wrong, or can the Pic just not handle that high of a data rate? I think that it must be me, since I don't notice any other problems (dropped or corrupted data, etc), unless I try to use the STR or SKIP commands (WAIT works fine!).
    **shrugs.
    **grins.
    Any suggestions?
    Thanks again,
    Ian
    I have used the example I gave you at low baud rates (eg 2400) without problems. It could be you're asking too much of your PIC. Try with a slower baud rate and move up in stages. Whenever I get problems I always revert to a known datum point where everything should work, and move forward from there.
    This works fine on a 16F876A @20MHz with PBP v2.46. I changed the port
    pins, and used true mode through a max232, but it works as expected. With
    or without the character pacing.
    DEFINE OSC 20
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    DEFINE DEBUG_MODE 0 ' 1 = inverted, 0 = true
    DEFINE DEBUGIN_REG PORTC
    DEFINE DEBUGIN_MODE 0 '1=inverted, 0=true
    reply  var byte
    msg  con "~"
    timeout  con 5000 ' Note change from (timeout con byte)
    reply = 5 ' receive 5 characters in payload string
    Main: ' Display "Waiting..." every 5 seconds if timeout period expires
        DEBUGIN timeout, error, [WAIT(msg), Skip 13, STR payload\reply]
        Debug "Received: ", STR payload\reply,13,10
        Goto Main
    Error:
        Debug "Waiting...",13,10
        goto Main
    Sending ~ABCDEFGHIJKLMNOPQR from MCS terminal to the PIC it displays;
    Waiting...
    Received: NOPQR ' ABCDEFGHIJKLM are skipped, NOPQR are received
    Waiting...
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. SERIN2 freezes
    Last Post: - 19th December 2009, 00:50
  2. LOW PORTA cause serin2 not working.
    By mikewen in forum Serial
    Last Post: - 28th August 2009, 05:18
  3. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 03:38
  4. Replies: 288
    Last Post: - 25th August 2008, 17:53
  5. Help with STR ArrayVar\n\c with SerIn2
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 15th May 2006, 02:04
