60Hz timebase clock
Results 1 to 8 of 8
    Default Re: 60Hz timebase clock
    Quote Originally Posted by astouffer View Post
    ... The power company makes small frequency adjustments over a 24 hour time so it always averages to 60Hz...
    I didn't know they bothered.
    If you're only interested in triggering an event every 60 Hz, have you looked at Darrel's interrupt I posted above? You can control the exact hertz you want a trigger without external parts. If you're not going faster than 16 MHz it's perfect for you.
    Apr 2011
    Welches, Oregon
    Well, since you promised to appreciate any comments...
    I'd use an RTC anyway. Some of the DS series are cheap, do not require a backup battery (actually, even those that make the option available need not have it to run) and provide a 1 Hz output without setting the time explicitly. Not sure why you wouldn't want to have a battery backed up time at your disposal, but if you don't... [shrug] ... you don't have to use it.
    There's also a good article here somewhere about making a very accurate 1 second timer with no other time base than an external crystal... that would be my second choice.
    On the other hand, Robert's suggestions are valid - as are your own.
    Nov 2008
    Amoque: Using the 60Hz power for a source will give me more accuracy than an RTC chip and be cheaper. I actually built a large clock based on the link you posted. It worked great but requires long term tweaking for accuracy. Even a 20ppm crystal it still gained a minute or two every month. Here is me testing one of the digits
    This code runs on a 16F684 and blinks an LED on pin 10 at 1Hz when fed a 60Hz input on pin 11. Of course the final version will be doing much more than blinking an led. I plan to use four IV-9 numitron tubes for the digits. http://hackadaycom.files.wordpress.c...2/numitron.jpg
    @	__CONFIG _FOSC_INTOSCIO & _WDTE_OFF & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _BOREN_OFF & _IESO_OFF & _FCMEN_OFF
    OSCCON = %01110101			'Internal OSC 8MHz
    DEFINE OSC 8				'8MHz
    PORTA = 0					'All low
    TRISA = %00000100			'Porta.2 input
    ANSEL = 0					'No analog
    WPUA = 0					'Weak pull up off
    CMCON0 = %00000111			'Comparators off and I/O is digital
    ADCON0 = 0					'A/D is off
    CCP1CON = 0					'PWM and CCP off
    OPTION_REG = %11111000		'Timer0 on
    TMR0 = 195					'Preload so it rolls over on the 60th pulse
    INTCON = %11100000			'INTCON.2 overflow bit
    on interrupt goto blink
    	@ NOP
    disable
    blink:
    toggle portc.0
    TMR0=195
    INTCON.2 = 0
    resume
    enable
    Almost forgot the basic schematic. Use a scope to see what resistor values give you the best output. My meter read 3mA going into a 4N25 optic isolator. http://i.imgur.com/fHWGJHr.jpg
    Apr 2011
    Welches, Oregon
    Ok... I didn't mean to infer I didn't think it would work. I know LOTS of cheap kitchen clocks use that method for just the reasons you state (cheap and accurate). Probably an easy way to get the whole assembly is to hit up Goodwill and look through the clocks...
    Me? I tend to overcomplicate things. I'd probably order up the DS3231 module from Banggood for $2.70, then display the date, day of the week, daily hi and low temperature... In the end, if I wanted to know the time, I'd end up having to look at my watch!
    Nov 2008
    Ok so apparently my math skills may be a bit rusty Doing some initial testing the timekeeping part seemed to be losing a few seconds pretty quickly. TMR0 should be 196!
  1. Replies: 14
    Last Post: - 8th March 2012, 03:04
  2. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 18:44
  3. Clock
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 1st February 2008, 03:23
  4. Power line timebase
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 6th March 2007, 17:13
  5. Xin & Xout Europe (50hz) vs US (60hz)
    Last Post: - 2nd May 2005, 12:49
