What am I doing wrong? 16F628A
Results 1 to 7 of 7
    Jan 2010
    Default What am I doing wrong? 16F628A
    Hi Guys,
    It should be pretty straight forward, but I'm at a loss. Trying to use a 16F628A and tried searching online for similar issues, but have been unsuccessful in resolving the matter.
    I wrote out a large amount of code. Found that one of the outputs on the PIC wasn't doing what it was suppose to do. To make a long story short, I wrote a small bit of code to test the outputs I wanted to control and it's still not working. I tried programming new chips, and get the same result.
    My problem: porta.4 (pin 3) does not want to turn on. It stays low and does not activate to control a transistor. I replaced the transistor (in case it was bad), and get the same result. Can someone tell me what I'm missing.
    Tony
       __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _LVP_OFF & _CP_OFF & _PWRTE_ON & _MCLRE_OFF & _BOREN_OFF
    Reset:
      CMCON = 7                     ' Analog comparators off
      VRCON = 0                     ' A/D Voltage reference disabled
      TRISA = %11000001             ' sets pin as input (1) or output (0)
      TRISB = %00110011             ' sets pin as input (1) or output (0)
      PORTA = %00000000             ' sets outputs as high (1) or low (0)
      PORTB = %00000000             ' sets outputs as high (1) or low (0)
    ' -----[ Variables ]-------------------------------------------------------
        rightrelay    var   porta.1  ' right relay output
        leftrelay     var   portb.2  ' left relay output
        rightfet      var   porta.4  ' right fet output
        leftfet       var   porta.2  ' left fet output
    high leftrelay
    high rightrelay
    action:
    low leftfet
    high rightfet
    low rightfet
    high leftfet
    goto action
    May 2008
    Italy
    Default Re: What am I doing wrong? 16F628A
    PortA.4 is an open drain port. You must use a pullup resistor in order to drive your transistor.
    Cheers
    Al.
    Aug 2008
    Portugal
    Hi;
    To complement aratti answer, that information is on the Datasheet.
    Thanks and Regards;
    Gadelhas
    Jan 2010
    I'm using an npn, so using a pull-up resistor turns on my transistor. Any other thoughts, or an equivalent chip to the 628A that does not have an open drain output?
    Tony
    Use the pullup and reverse your high and low. up is down and down is up...
    Or use a PNP, or invert the signal with another transistor or use an 16F88, 16F819, 16F1826 etc etc.
    If buying new, go for the enhanced 16F1xxx series, cheaper and better in all respects I can think of.
    Selecting 8-bit chips with 18 pins in the Microchip Advanced Part Selector, gives 17 different parts, pick one and look at the datasheet.
    Jan 2010
    Unfortunately, I'm using an npn to control a p-channel mosfet, so I can't change the layout. Thank you for the link. That is extremely helpful.
    Tony
  1. What am I doing wrong?
    By tazntex in forum mel PIC BASIC Pro
    Last Post: - 13th July 2010, 16:43
  2. What am I doing wrong?
    Last Post: - 13th October 2009, 20:46
  3. Would you like to look what is wrong?
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2008, 17:51
  4. what do i do wrong?
    By Automan in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2008, 13:27
  5. What am I doing wrong ?
    Last Post: - 10th June 2006, 00:12
