10F222 Wake on pin change
Results 1 to 12 of 12
    Sep 2010
    Las Vegas, NV
    Default 10F222 Wake on pin change
    Ladies and Gents,
    For some reason I keep trying to use smaller PICs instead of larger. My query today is about the Wake-on-pin change feature of the 10F222 and how to implement it.
    I've got this program that while sleeping is pulling around 3uA at 6ish volts which is pretty good but I want, well, less. I'm not using a voltage regulator and am feeding 4 x AAA battery voltage to the circuit/PIC. My question is, is this the correct way to implement a wake on pin change? I think this is just a loop that naps alot and that's why it uses so little power not a wake on pin change.
    clear
    define OSC 4 ' if changed make sure to change config statement
    adcon0 = 0         ' Turn off ADC
    option_reg = %01000000 ' 7 = !GPWU wake on pin change. 6 = !GPPU weak pull up
    status = 0
    osccal = %00000000  ' oscillator calibration
    trisio = %1000      ' All but GP3 is output
    gpio = 0
           __config _IOFSCS_4MHZ & _WDT_ON & _MCLRE_OFF & _CP_OFF
    GREEN var gpio.1             '-----------------------------variables and constants
    RED var gpio.0
    BLUE var gpio.2
    SWITCH VAR GPIO.3
    state var byte
    start_here:                  ' ------------------------------finally the program
    state = gpio  ' read the gpio ports
    adcon0 = 0 ' I read somewhere that after a reset you need to set this register again
    nap 5
    if switch = 0 then gosub light_LED ' looking for the button
    goto start_here
    light_led:         '-----------------------------------------------------led sub
    red = 1
    red = 0
    green = 1
    green = 0
    blue = 1
    GREEN = 1
    red = 1
    GPIO = 0
    I didn't add a schematic so I hope a word picture will do. The LED cathodes are connected to ground and the anode to a resistor, forget size, and the resistor to PIC port pins. The switch is between the PIC and ground. I know I could get lower current if I used a slower oscillator but that will take up two pins leaving me only 1 output pin. My ultimate goal is to have this battery powered device sit on the shelf for a very long time without having to change the batteries.
    I'd appreciate some learning if someone would be willing to part with it.
    Default Re: 10F222 Wake on pin change
    When using the NAP command the PIC goes to sleep, for a while, wakes up, goes to sleep, wakes up and so on, keeping track of how many "cycles" in order to give you roughly the amount the sleeptime you tell it to. It uses the WDT to do this.
    Using Wake-on-change will put the PIC to sleep and it'll stay there until a change occurs. I've never used the feature and I've never used the 10F parts but it looks like all you need to do is enable GPWU (like you are doing). Then when you're ready to go to sleep you do a read of the GPIO register to get the current state and then put the chip to sleep using the assembly instruction SLEEP (not the PBP command) ie, @ SLEEP
    At this point the PIC will go to sleep until a change occurs on one of the GPIO pins which are set to be inputs. I think that you'll have to disable the WDT otherwise IT will timeout and Wake the PIC up.
    @ SLEEP
    goto start_here
    Again, I've never actually tried this, just read the datasheet so take it for what it is.
    With that said I really wouldn't want to run it at anything above 5.5V......
    Aug 2008
    Portugal
    Hi;
    Here is a program that i wrote in the past.
    '*  Name    : Temporizador 3m p/ Lavar Dentes.BAS               *
    '*  Author  : gadelhas                                          *
    '*  Notice  : Copyright (c) 2012 ProSystems                     *
    '*  Date    : 01-03-2012                                        *
    '*  Notes   : Proteus + Circuito com SOT-23 e CR2032            *
    '*          : 10F222 - Wake from sleep através de IOC no GP3    *
    @ __config _IOFSCS_4MHZ & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _MCPU_ON
     '===================SRF AND PINOUT CONFIGURATION - 1-In / 0-Out=================
                  '76543210
         TRISIO = %00001000
           GPIO = %00000000
     OPTION_REG = %00000000 'OPTION_REG.7 - Wake on change bit 0=Enable
         ADCON0 = %00000000 'Analog pins disable
    '==================================ALIAS========================================
     VAZIO1 VAR GPIO.0
     VAZIO2 VAR GPIO.1
     LED    VAR GPIO.2
     MCLR   vAR GPIO.3
     GPWUF  var STATUS.7
    '=================================VARIABLES=====================================
     I VAR BYTE
     C VAR BYTE: C = 0
    '================================MAIN LOOP======================================
    @ movlw 0x01A  ;OSCCAL Value
    @ movwf OSCCAL
     IF GPWUF = 0 THEN DESLIGA  'Test what caused the Reset
     WHILE MCLR = 0    'If button pressed for 3 seconds, turn on led
        PAUSE 100
        C = C + 1
        IF C = 30 THEN LIGA
     WEND
     FOR I = 0 TO 119 '~120 Segundos a Piscar de 1 em 1 Segundo
        HIGH LED
        PAUSE 500
        GOSUB VERIFICA
        LOW LED
        PAUSE 500
        GOSUB VERIFICA
     NEXT
     FOR I = 0 TO 59  '~30 Segundos a Piscar de 0,5 em 0,5 Segundo
        HIGH LED
        PAUSE 250
        LOW LED
        PAUSE 250
        GOSUB VERIFICA
     NEXT
     HIGH LED
     FOR I = 0 TO 59  '~30 Segundos sempre ligado
         PAUSE 500
         GOSUB VERIFICA
     NEXT
     LOW LED
     'Sequencia de finalização
     HIGH LED: PAUSE 100: LOW LED: PAUSE 100
    DESLIGA:
     C = 0
     I = GPIO     'Must read GPIO before entering sleep. Read the Datasheet
    @ SLEEP
    @ NOP
    GOTO Main
    '================================SUB-ROUTINES===================================
    LIGA:
        HIGH LED
        PAUSE 1000
        WHILE MCLR !=0
        WEND
        LOW LED
    GOTO DESLIGA
    VERIFICA:
     IF MCLR = 0 THEN
         C = C + 1
         IF C = 6 THEN
             PAUSE 1000
             GOTO DESLIGA
    Thanks and Regards;
    Gadelhas
    I agree...But for that you can just add a diode in series to lower the voltage down a bit.
    Rui
    Sep 2010
    Las Vegas, NV
    Good idea on the diode. Thanks.
    I know what RTFDS says but for what I'm doing I assume the four AAA batteries are putting out somewhat less than 1.5V and typically the four pack is close to 5.6V. After a short period they are below the 5.5V level and stay like that for a long time with only a 3uA draw. They'll last even longer if I can get it down in the nano Amp range.
    I've yet to try the ASM sleep but will try soon. Thanks for ideas.
    Dec 2010
    Brand new batteries will actually put out more than 1.5V. I'd recommend the diode. Also helps for the day you accidentally put them in backwards. Or use NiCDs.
    Would a low drop off 7805 help?
    Dec 2010
    How low is low? They usually need over a volt. Can you point to a spec sheet?
    I don't really see the point of linear regulator. A 5V one, LDO or normal, will drop out of regulation pretty quick, then it behaves as if it wasn't there in first place - or worse. Using a lower voltage like 3.3V or 2.5V will only turn useful energy into heat in the regulator so that's no good either.
    The "best" way would of course be a switching type boost/buck converter/regulator so that the PIC can be fed 2.5V (or whatever) from "any" supply voltage, the good thing about this is that the PIC Draws much less current at lower supply voltages so provided the converter/regulator is efficient you'd get more use out of the batteries. But, it adds complexity so.....perhaps use 3 cells in series instead of 4.
    Quote Originally Posted by Charlie View Post
    I haven't used one yet. I checked a few and can't find one that comes even close to what is needed here.
    They should call them NAMDO; Not As Much Drop Off instead of LDO.
    For reference, the LP2950 has a maximum specified drop out voltage of 450mV @100mA load and 80mV @100uA. But like I said, for this application, I don't think using a linear regulator is a good idea.
    The quiescent current of the regulator alone (the LP2950 that is) is 75uA which isn't much but it means that the regulator alone pulls like 50-100 times more current than the PIC does when it's sleeping.
    Nov 2007
    West Covina, CA
    This is part of a program I used to put a PIC16F685 to sleep running at 8MHz.
    The unit runs on a CR2032 coin cell and managed to get it down to less than 50nA in Sleep mode.
    I had to make sure the circuit was not going to be sourcing power to anything while on standby and it's important to shut things OFF before bedding down.
    I read somewhere that the @ NOP after the @ SLEEP would be needed and found it would not stay asleep unless it was there. Hey, as long as it worked!
    '                           SLEEP Mode
    ' This routine provides an Ultra Low power consumtion until a button is
    ' pressed. All I/O's are setup for the PORTA/B Interrupt On Change function
    ' prior to going into standby condition. Any state change detected to these
    ' PORTs starts main and directs to proper routine.
     Sleep_mode:
        OPTION_REG.7 = 0    ' Global weak pull-up enable bit enabled
        WPUA = %00011111    ' Weak pull-ups enable on PORTA inputs except RA5
        WPUB = %00000000    ' Weak pull-ups disabled on PORTB
        MOSI = 0            ' Turn OFF SPI data line
        _CSN = 0            ' Turn OFF module select line
        TXEN = 1            ' Transmitter Vcc OFF
        SEND = 0            ' Turn OFF MS encoder SEND input
        Action = 0          ' Turn OFF all outputs
        m = 0               ' Mode counter reset
        IOCA = %00000110    ' Mode input pin RA4 configured for IOC.
        IOCB = %10000000    ' ID_new input pin RB7 configured for IOC.
        Store_A = PORTA     ' Reads PORTA
        Store_B = PORTB     ' Reads PORTB
        INTCON = %00001000  ' RABIE (RA and RB Interupt Enabled)
        @ SLEEP             ; Goes mimi until a change of state is detected
        @ NOP               ; 1 instruction cycle
    Louie
  1. 10F222 wake/sleep
    By AvionicsMaster1 in forum PBP3
    Last Post: - 23rd August 2013, 09:03
  2. Interrupt-on-Change-pin!
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 11th February 2009, 21:22
  3. HELP !!! How change the voltage of a pin ????
    By stormdacta in forum mel PIC BASIC Pro
    Last Post: - 21st August 2007, 21:55
  4. ? about sleep/wake on pin change and WDT
    By kessral in forum mel PIC BASIC Pro
    Last Post: - 26th January 2007, 00:25
  5. 16F676 Interupt on Change pin determination
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 5th May 2006, 18:04
