BH1750FVI sample code available?
Results 1 to 15 of 15
    Default Re: BH1750FVI sample code available?
    each and every i2c command has incorrect syntax
    Well, I tried to use what I already have working for DS3231
    Manual is not very clear about I2C....
    Changed syntax, still getting zeroes, what I'm doing wrong?
    ldta  var porta.6
    lclk  var porta.3
    x var word
    y var byte
    z var byte
    cnt var byte 'control word
    adr var byte
    sda var portc.0
    scl var portc.1
    lcdout $fe, $01, " "
    adr=$23
    x=0
    cnt=%0100011
    i2cwrite ldta, lclk, cnt, adr
    pause 200
    cnt=%00010001
    pause 200
    maik:
    cnt=%0100011
    i2cread ldta, lclk, cnt, adr, x
    pause 200
    lcdout $fe, $1, dec x
    pause 200
    goto maik
    Bombay, India
    1 - use the appropriate I2C address for the device based on the hardware pin state
    2) Slave Address
    Slave Address is 2 types, it is determined by ADDR Terminal
    ADDR = ‘H’ ( ADDR ≧ 0.7VCC ) → “1011100“
    ADDR = 'L' ( ADDR ≦ 0.3VCC ) → “0100011“
    2 - the device address for case 1 is $B8 and case 2 is $46 (use one of these values in cnt)
    When you put the address as shown in your code, the leading bit is 0 and the address will be $5c or $23. This is definitely wrong.
    3 - cnt remains the same for I2CWrite and I2CRead. the least significant bit is changed internally by the compiler depending on whether the command is a read or write
    Thanks!
    Tried both, none works, so I guess, I'm missing something else too...
    Bombay, India
    You ought to be sending this way
    Assuming ADDR pin is low
        i2cwrite ldta, lclk, $46, adr,  dat
    and read by
        i2cread ldat, lclk, $46, adr, dat
    make sure the adr and dat match with the register of the device and dat relevant to the register. It should work.
    not in my view
    addr var byte
    addr= $46
    i2cwrite sda,sck,addr,[opecode]
    i2cread sda,sck,addr,[dat.highbyte,dat.lowbyte]
    Last edited by richard; - 17th May 2022 at 03:56. Reason: got rid of ridiculous alias names
  1. please who can help me for sample code
    By jasem700 in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 21:41
  2. USBJADEM sample code
    By SterlingY in forum mel PIC BASIC Pro
    Last Post: - 14th March 2007, 01:57
  3. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  4. Sample code for pwm
    By Md.Shah in forum mel PIC BASIC
    Last Post: - 10th October 2006, 17:59
  5. 12F675 code sample
    By marad73 in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2006, 14:53
