DT-ints-18, How to ...
Results 1 to 19 of 19
    Jun 2008
    Varese , Italy
    Default DT-ints-18, How to ...
    Good Day to all of you in the forum,
    I will like to have some direction on how to generate an interrupt ( used to call up a subroutine ) every 10 ms.
    I will like to know how to set_up the system to get interrupts at a desired period
    I am using PICbasic pro 2.50 and DT-ints-18. Pic is 18f4523 running at 40 MHz.
    Thanks in advance for any help.
    Ambrogio
    Default Re: DT-ints-18, How to ...
    Have you looked at the examples provided by Darrel on his site where you downloaded the DT-Ints files?
    May I suggest you use this one as a starting point. The example lets TMR1 free-run so the interrupt triggers at a given frequency (each time TMR1 overflows).
    To change the frequency you reload the timer with a specific value each interrupt, so that it starts from a value other than zero.
    See if you can get that example to work as is for starters.
    Steve Monfette ... aka DJ KeeWee ... aka Mr E ...
    published here ( 2004 ) a phase control dimmer project where everything was shown ...
    don't remember if using DT Interrupts ... but working !!!
    the code ...
    http://www.picbasic.ru/_fr/3/LampDim.bas
    Jun 2008
    Varese , Italy
    Thanks Heirik and Acetronics2.
    I will go on with your indications.
    My antivirus does not allow to me to open the following :
    Any possibility to have the files posted to me ?
    Ambrogio
    [email protected]
    Right click and save as ?
    Jun 2008
    Varese , Italy
    The problem is that my antivirus does not allow me to enter that link.
    Ambrogio
    Will this work for you?
    LampDim.bas
    Jun 2008
    Varese , Italy
    I have loaded the program as indicated .
    No errors displayed.
    I am using pbp 2.50, picf184523 @ 40 MHz speed.
    I have a square wave output at porta.4 and 100 msec period ( 50 msec high and 50 msec low ).
    Where does the 100 msec come from ?
    How could I set different periods ?
    The program is attached here.
    Ambrogio
    'HSPLL OSCILLATOR HAS BEEN DEFINED IN THE PBP FOLDER > 18F4523 FILE
    DEFINE OSC 40
    LED1 VAR PORTA.4
    INCLUDE "DT_INTS-18.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP interrupts
    INT_Handler TMR1_INT, _ToggleLED1, PBP, yes
    T1CON = $31 ; Prescaler = 8, TMR1ON
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    PAUSE 1
    GOTO Main
    ToggleLED1:
    TOGGLE LED1
    @ INT_RETURN
    It comes from the formula ...
    1/(OSC * 1000000 / 4 / Prescaler / 65536)
    1/(40 * 1000000 / 4 / 8 / 65536) = 0.0524 Sec. = 52.4 mS
    Times 2 for a full cycle = 104.8 mS
    If the frequency is fixed, use the Timer Template ...
    http://darreltaylor.com/DT_INTS-14/TimerTemplate.html
    Do we just change these to their 18F counterparts for 18F PICs?
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas'
    Jun 2008
    Varese , Italy
    Thanks Darrel for the assistance.
    I red the pic18f4523 spec and I am just a little bit confused on how write and read the timer1 counter that is 16 bit long.
    What is the picbasic code to read and write that 16 bit timer/counter ?
    Your responses are always sharp an relly effective: congratulation.
    Best regards,
    Ambrogio
    IW2FVO
    IW2FVO,
    To read the timer:
    variable var word
    variable = tmr1
    To write the timer:
    tmr1 = variable
    Its just that simple....
    EN82fn
    Jun 2008
    Varese , Italy
    thanks,
    if I write tmr1= 64 then the compiler gives me :
    >> error 113..... pbpp18.lib580 : symbol not previously defined (tmr1 ) and then the same message but lib588, lib927, lib 933.
    So the point is still : how to read / write TMR1 ?
    Any help is appreciated.
    Ambrogio
    Is post #10 above the issue?
    It's easy but I'm afraid it's not THAT easy - there is no TMR1 register (hence the error). Instead TMR1 consists of TWO 8bit regsiters, TMR1L and TMR1H.
    The straight forward way to write it is to do
    TMR1L = 0
    TMR1H = 0
    And the straight forward way to read it is
    myVar VAR WORD
    myVAR.HighByte = TMR1H
    myVAR.LowByte = TMR1L
    When reading TMR1 this way there's a slight posibillity that TMR1L overflows right in between reading TMR1H and TMR1L giving you a wrong result. To prevent that the easiest way is to simply STOP the timer before reading it. If that's not possible there are other ways to cater for that - and there are tricks that allows you to read it in one go if needed but lets keep it as simple as possible for now.
    If you are using the Timer Template, then there's no reason to read or write to the Timer directly. It is handled for you by the template.
    If you are not using the template, you should at least use the Timer Reload routine from the template.
    To maintain a constant frequency that also accounts for interrupt latency, the reload value must be ADDED to the current value in the Timer.
    Just reloading a value into the Timer will give a frequency output, but accuracy and consistency will suffer.
    There are other ways to ADD the reload value to the Timer, but you must know exactly how many instructions it takes to do the addition.
    The routine in the template is already known to take 8 instruction cycles.
    The template automatically adjusts for that amount of time.
    With the template, if you tell it you want 100hz ... you get 100.0 Hz.
    With all of that said ... you still haven't revealed whether you want a Fixed frequency or Variable frequencies?
    It makes a huge difference.
    Jun 2008
    Varese , Italy
    Thanks to everybody for the assistance.
    yes, I need a fixed frequency so I can use the timer tamplate. >> Is this table applicable to pic18f4523 ?
    Additional question:
    >> what is the purpose of bit_7 ( rd16 ) in the t1con register? How to use it ?
    >> what is the purpose odf the RESETFLAG? yes/no in the DT _int ?
    Ambrogio
    The table is applicable to all PIC's, but it doesn't include the higher OSC frequencies of the 18F's.
    If your interrupt frequency is greater than 160 Hz (80 Hz Full Cycle), you don't need to worry about the table.
    Just set Prescaler to 1 and Freq to your frequency.
    The RD16 bit buffers the highbyte of the Timer so that both bytes can be read or written without stopping the Timer.
    The Timer Template will not work with RD16 set.
    With interrupts that require you to manually clear the interrupt flag, setting RESETFLAG to YES will allow DT_INTS to clear it for you.
    Jun 2008
    Varese , Italy
    Thanks again Darrel for the great assistance.
    regards,
    Ambrogio
    IW2FVO
    North Italy
  1. DT INTs which int to use??
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 13th March 2012, 00:23
  2. out of memory using DT-ints-14 and 16F610
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 7th January 2011, 03:30
  3. DT-INTs Blinky Light question
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 5th February 2010, 03:29
  4. Problem with Dt Ints Interrupts
    By Quin in forum mel PIC BASIC Pro
    Last Post: - 18th July 2008, 19:21
  5. DT-ints-18 - new version
    By dip1 in forum mel PIC BASIC Pro
    Last Post: - 10th October 2007, 20:09
