DT-ints-18, How to ...
Results 1 to 19 of 19
    Jun 2008
    Varese , Italy
    Default DT-ints-18, How to ...
    Good Day to all of you in the forum,
    I will like to have some direction on how to generate an interrupt ( used to call up a subroutine ) every 10 ms.
    I will like to know how to set_up the system to get interrupts at a desired period
    I am using PICbasic pro 2.50 and DT-ints-18. Pic is 18f4523 running at 40 MHz.
    Thanks in advance for any help.
    Ambrogio
    Default Re: DT-ints-18, How to ...
    Have you looked at the examples provided by Darrel on his site where you downloaded the DT-Ints files?
    May I suggest you use this one as a starting point. The example lets TMR1 free-run so the interrupt triggers at a given frequency (each time TMR1 overflows).
    To change the frequency you reload the timer with a specific value each interrupt, so that it starts from a value other than zero.
    See if you can get that example to work as is for starters.
    Steve Monfette ... aka DJ KeeWee ... aka Mr E ...
    published here ( 2004 ) a phase control dimmer project where everything was shown ...
    don't remember if using DT Interrupts ... but working !!!
    the code ...
    http://www.picbasic.ru/_fr/3/LampDim.bas
    Jun 2008
    Varese , Italy
    Thanks Heirik and Acetronics2.
    I will go on with your indications.
    My antivirus does not allow to me to open the following :
    Any possibility to have the files posted to me ?
    Ambrogio
    [email protected]
    Right click and save as ?
    Jun 2008
    Varese , Italy
    The problem is that my antivirus does not allow me to enter that link.
    Ambrogio
    Jun 2008
    Varese , Italy
    I have loaded the program as indicated .
    No errors displayed.
    I am using pbp 2.50, picf184523 @ 40 MHz speed.
    I have a square wave output at porta.4 and 100 msec period ( 50 msec high and 50 msec low ).
    Where does the 100 msec come from ?
    How could I set different periods ?
    The program is attached here.
    Ambrogio
    'HSPLL OSCILLATOR HAS BEEN DEFINED IN THE PBP FOLDER > 18F4523 FILE
    DEFINE OSC 40
    LED1 VAR PORTA.4
    INCLUDE "DT_INTS-18.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP interrupts
    INT_Handler TMR1_INT, _ToggleLED1, PBP, yes
    T1CON = $31 ; Prescaler = 8, TMR1ON
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    PAUSE 1
    GOTO Main
    ToggleLED1:
    TOGGLE LED1
    @ INT_RETURN
  1. DT INTs which int to use??
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 13th March 2012, 00:23
  2. out of memory using DT-ints-14 and 16F610
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 7th January 2011, 03:30
  3. DT-INTs Blinky Light question
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 5th February 2010, 03:29
  4. Problem with Dt Ints Interrupts
    By Quin in forum mel PIC BASIC Pro
    Last Post: - 18th July 2008, 19:21
  5. DT-ints-18 - new version
    By dip1 in forum mel PIC BASIC Pro
    Last Post: - 10th October 2007, 20:09
