32 LEDs with less than 20mA
Results 1 to 12 of 12
    Default Re: 32 LEDs with less than 20mA
    Figured out how to have same current at the LEDs no matter how many are used; set pin even if bit received from Master is a 0. So now it always take the same amount of time to go through the loop. Post is updated:
    http://www.picbasic.co.uk/forum/show...843#post124843
    Used NPN 2N2222 transistors to drive the LEDs. So now I've moved the problem of the PIC having a pin frozen ON, to a transistor frozen ON. Not enough experience to know if it is worth the extra parts.
    Transistors do bring another problem, it now takes a 100mA to drive all LEDs ON; a lot more than using the pin to LED to 0VDC technique. I don't know enough about transistors; I'm guessing it has something to do with switching times, I must have more than one still leaking current even if the PIC decided the pin is at 0VDC. LED loop is now running at 668 Hz according to Saleae probe.
    I have no experience using LED driver ICs (none on hand). I have to research those; they must bring in safeguards and fewer parts count into the picture. Is one more interesting in particular?
    The system will never have 32 LEDs ON, that was a stress test. Only one side can be lit at any one time, and that's if I disabled the zone or the zone is open; highly unlikely all 15 rows will be ON. SO current will not really be an issue, I was just hoping to get it as efficient as possible.
    Also, the panel won't be active all the time. You'll have to press the * on the keyboard, that will help conserve current when using battery mode even more.
    Sidenote: I had one LED that was always dimmer than the others. I changed pin, LED, even the transistor, no difference. Turns out the 4K7 resistor was way off (gold tolerance), replaced and LED now same as others. First time I get one of those that is so far off that it affects LED brightness this much.
    Great bi-directional multiplex design here:
    http://www.picbasic.co.uk/forum/showthread.php?t=14439
    Only 5 pins to drive 16 LEDs.
    Woot!
    Robert The Happy Camper
    CURRENT SAVING UPDATE
    Transistors are out, back with current limitting resistors and ultra bright LEDs.
    Old "frosted?" green 5mm LED with 330R: 40 LUX using 9mA
    New clear ultrabright green 5mm 10000 MCD LED with 1K at 90Hz: 40 LUX using 0.053mA
    Tested using AR813 Lux Meter.
  1. Creating 4 to 20MA ?
    By amgen in forum Off Topic
    Last Post: - 3rd May 2014, 23:45
  2. 4-20mA using SPI Interface
    By gavo in forum mel PIC BASIC Pro
    Last Post: - 10th April 2013, 20:51
  3. 4-20mA output using PWM
    Last Post: - 8th December 2007, 10:45
  4. 4-20mA current loop
    By mychangl in forum General
    Last Post: - 20th April 2007, 12:41
  5. 4-20mA to 0-5V configuration
    By leonel in forum General
    Last Post: - 31st August 2005, 13:33
