32 LEDs with less than 20mA
Results 1 to 12 of 12
    Default 32 LEDs with less than 20mA
    Just an example of how little current is required to light 32 LEDs simultaneously:
    18F44K22 using internal oscillator at 64MHz
    LED turned ON
    PAUSEUS 500
    LED turned OFF
    PAUSEUS 500
    ...repeat for 31 other LEDs
    Not bad, 18.97mA for 32 LEDs and PIC mcu.
    To the naked eye, they all appear ON without blinking. A little pale, I could reduce the 330ohm resistor a little bit, maybe 270ohm, but this was taken under the kitchen light.
    Miami, Florida USA
    Default Re: 32 LEDs with less than 20mA
    Not really . I have a similar project where I drive 8 digits in an LED display by multiplexing them one at a time. Also, to the naked eye they all appear to be ON at the same time.
    Anonymous
    They are lit simultaneously, but look at the code, they blink one at a time.
    Oct 2009
    Utah, USA
    Wow demon,
    that's a LOT of LED's
    Hop over to ebay and search on "rapid prototyping LED"
    You will find some nice little LED modules all wired up with resistors ready to pop into your bread board. Just ordered me some green ones.
    They are all 6 LED's per module I couldn't find any that were 8. But still pretty nice and easy to use.
    Dwight
    Oct 2009
    Utah, USA
    actually here are some that are 8 LED's per module.
    But they are a little different in the way they pinout
    and quite a bit more money... about $10US including shipping versus about $2 shipped for the 6 LED ones.
    http://www.ebay.com/itm/Rapid-Protot...#ht_2014wt_805
    Dwight
    Did I mention I have a boatload of Leds and resistors? LOL
    I bought a wide variety on ebay several years ago, knowing I'd use them in projects eventually.
    I have enough "stuff' to print barcodes and start an inventory (future android project).
    So many ideas, so little will power.
    Edit: oh yeah, those are neat. Must cut down on setup time when you have a lot in your circuit.
  1. Creating 4 to 20MA ?
    By amgen in forum Off Topic
    Last Post: - 3rd May 2014, 23:45
  2. 4-20mA using SPI Interface
    By gavo in forum mel PIC BASIC Pro
    Last Post: - 10th April 2013, 20:51
  3. 4-20mA output using PWM
    Last Post: - 8th December 2007, 10:45
  4. 4-20mA current loop
    By mychangl in forum General
    Last Post: - 20th April 2007, 12:41
  5. 4-20mA to 0-5V configuration
    By leonel in forum General
    Last Post: - 31st August 2005, 13:33
