Programming 12F683 in QBASIC
Results 1 to 18 of 18
    Oct 2009
    Utah, USA
    Smile Re: Programming 12F683 in QBASIC
    Camerart,
    Yeah, sorry, it is the TRISIO register that defines the In/Out direction of each pin on the 12f683 (again you MUST consult the datasheet as it is likely named something else on a different PIC). But there is a hardware limitation on GP3, that pin can NEVER act as an output, regardless of what is in that bit position of the TRISIO register.
    So I am curious about this QBASIC that you are using for writing PIC programs.
    Can you provide a link to it?
    The PBP compiler that this forum supports is going to be VERY similar to any other "basic" language. With some minor differences that should be easy to learn.
    It is a VERY powerful compiler and well supported.
    The website for PBP is http://melabs.com
    It is a bit of an expense to purchase but well worth it
    There are some world class sofware and hardware folks that hang around here, and are very willing to help (as long as the asker shows some amount of effort before asking.)
    Most of the code examples that you will find on the PIC datasheets is going to be in assembly or machine code, not in a higher level language like basic.
    good luck and keep asking questions.
    Dwight
    Dec 2010
    Default Re: Programming 12F683 in QBASIC
    FYI - QBASIC is a relatively high level language compiled (or interpreted depending on the version) to run on DOS or Windows PCs. It was written by Microsoft, and discontinued many years ago when they moved to Visual Basic. I don't think there was ever a version that compiled for PIC.
    Jan 2013
    Hi Charlie,
    As I said I learnt basic basic, soon after it came out, and have continued ever since. I've considered learning other programs, but it was hard enough to do one time, so I didn't. I've made processing equipment, automatic vehicles, and lots small stuff, and still find it amazing to have flashing lights, once I get something working. Today I have almost finished programming a remote heater start-up switch so I can warm the vehicle up, 10 mins before getting in. I compile with picsimulatoreide, and burn with pickchip2. Simple, headachy, but fun!
    Cheers, Camerart.
    Dec 2010
    Glad you've had some successes. What you may not realize is that there are dozens of versions of BASIC targeting many different processing platforms, and many different versions even for the same platform. I can name a half dozen versions for PIC alone, not to mention a few for Android, and several for Windows. Saying you use BASIC is a little like saying you speak human.
    You are currently posting on a forum dedicated to only one of those flavors - apparently not the one you are using. A major advantage of this particular version of BASIC is a large group of users that help each other, as you are discovering. Many of the other versions also have helpful communities if you can find them. Unfortunately, other than very general things, you are not likely to get much specific help for your environment from the folks here. But welcome - there are lots of great ideas here, even if there won't be specific help. And who knows... you might even find a reason to "convert" :-)
    Jan 2013
    Hi Charlie,
    I did kind of realize that there are more versions of basic. I'm just glad I learnt 'QBASIC' when, and in the way I did or I would never have learnt any. I need to go into all sorts of efforts, to learn. At present I 'need' tolearn MORSE, and it's quite a challenge, for me anyway. I'm getting there.
    Cheers, Camerart. UK
    Quote Originally Posted by Charlie View Post
    Jan 2013
    SORRY!!!
    I have been informed that: I first learnt SPECTRUM BASIC,then QBASIC and now I'm using PICBASIC to program my PIC chips. It is confusing, at least for us oldies
    Cheers, Camerart.
    Dec 2010
    Getting closer... now which version of PICBASIC? Look for an *ABOUT* button.
    Jan 2013
    Hi Hecler,
    I thought I had already replied, but perhaps not. Here is a link to the kind of Basic I am using: http://www.qbasic.com/
    Cheers, Camerart.
    Camerart,
  1. first program 12f683
    By sparkness in forum mel PIC BASIC Pro
    Last Post: - 4th January 2014, 17:07
  2. 12f683 help!!!! L@@K!!!
    By thm ov3rkill in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2008, 23:46
  3. 12F683 Programmer
    By Red_Stafford in forum Schematics
    Last Post: - 2nd October 2008, 22:44
  4. Replies: 2
    Last Post: - 23rd July 2006, 09:16
  5. 12F683 Startup
    By GregK in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 01:25
