Programming 12F683 in QBASIC
Results 1 to 18 of 18
    Jan 2013
    Default Programming 12F683 in QBASIC
    I can't get a 12F683 PIC to accept inputs. Here is an example of what I've tried.
    '03.01.14
    'Test 12F683
    OSCCON = %01100000 'Internal 4MHz osc
    ADCON0 = 0 'A/D off
    CMCON0 = 0x07 'Comparators off
    ANSEL = 0 'Set all digital
    WPU = 0 'Internal pull-ups = off
    OPTION_REG = %10000000 'Pull-ups = off, GPIO.2 = I/O, prescaler to Timer1
    GPIO = %00000000 'All outputs = 0 on boot
    TRISIO = %00100100 'GPIO,0
    Config GP2 = Input
    start:
    If GP2 = 1 Then
    GP5 = 1
    Else
    If GP2 = 0 Then
    GP5 = 0
    Endif
    Endif
    Goto start
    At one time I had a TOGGLE LED to show it was working, and even though the program didn't work properly, did show a change when the input went high.
    I copied the top part where is sets up, and have changed it a little!
    Cheers, Camerart.
    Default Re: Programming 12F683
    Well, that code won't even compile with PBP, which compiler are you using?
    * The format 0x07 isn't supported in PBP, to write in hexadecimal notation use $07.
    * The individual bits on GPIO registers are accessed as GPIO.x not GPx.
    Try changing that for starters and see if it makes it better.
    Jan 2013
    Hi Henrik,
    I don't know what PBP means?
    I'm using what I know as qbasic, I'm too long in the tooth to change I'm afaraid. I use PICSIMULATORIDE for simulating and compiling, then PICKIT2 for burning.
    With the above set-up I can program 16F819 PICs and I've had the 12F683 with a LED flashing, but can't get any inputs.
    Cheers, Camerart.
    Jan 2013
    I now know what PBP means
    Anyway! I got a simple timer working, here is the code I used:
    '03.01.14
    'Test 12F683
    ADCON0 = 0 'A/D off
    CMCON0 = 7 'Comparators off
    TRISIO = %00001000 'GPIO,0=data in, GPIO,1=IRLED out, GPIO,2,3,4,5 unused
    Dim s As Byte 'Seconds
    'needs reset>>>>>>>>>>>>>>>>>>>>>>>.
    start:
    If GP3 = 1 Then
    Gosub sequence
    Endif
    Goto start
    sequence:
    GP5 = 1
    WaitMs 200
    GP5 = 0
    WaitMs 200
    GP5 = 1
    WaitMs 200
    GP5 = 0
    WaitMs 200
    For s = 0 To 52
    WaitMs 1000 '50 seconds
    Next s
    GP5 = 1
    WaitMs 200
    GP5 = 0
    WaitMs 200
    GP5 = 1
    WaitMs 200
    GP5 = 0
    WaitMs 200
    s = 0
    I noticed on the data sheet, it said "GP3 is only input" so I changed my input to GP3 and it works. I'm sure if I understood better, I could get more inputs though.
    Cheers, Camerart
    Default Re: Programming 12F683 in QBASIC
    I'm glad you figured it out!
    As you probably know, this forum is primarily targeting PBP (PIC BASIC Pro) from Micro Engineering Labs. Unfortunatley there are differences between various BASIC compilers so what applies to PBP may not be relevant to the compiler you're using.
    It's not that the people around here wouldn't want to help just because you're using another brand compiler but you'll most likely get much better help on a forum or newsgroup discussing the particullar compiler you're using.
    Oct 2009
    Utah, USA
    That GP3 has tripped me up more than a few times as I was just learning. That is true, it can only act as an input (or the MCLR, depending on your configuration fuses)
    In fact on all the PIC's that I have worked with so far... What ever pin is the MCLR pin can ONLY act as Input or MCLR.
    All the other 5 pins can act as either input or output depending on the TRISA register.
    Be sure and get (download) the datasheet for any PIC that you choose to work with.
    It is essential to refer to as you are setting up and defining the pin functions and other features (timers, A/D, PWM, etc).
    The configuration (CONFIG) register is the one that defines the function of that GP3 pin, (and other things like WDT, Brown Out Reset, etc). This register can ONLY be defined at the time you burn the program into the PIC. It can NOT be changed on the fly by your program as it runs. So you must choose how you want the bits in the CONFIG register set and leave them that way unitl you re-program the PIC.
    good luck
    Dwight
    Jan 2013
    Hi Heckler,
    I always download the datasheet, but I don't always quite understand them
    I don't think this chip has Trisa or trisb but has Trisio. I've tried various combinations of Trisio's but so far can only use GP3 as input. This is what my config looks like: TRISIO = %00000100
    In all of the examples on the datasheet, it shows language like in post #1, and I only know qbasic.
    Cheers, Camerart.
    Oct 2009
    Utah, USA
    Smile Re: Programming 12F683 in QBASIC
    Camerart,
    Yeah, sorry, it is the TRISIO register that defines the In/Out direction of each pin on the 12f683 (again you MUST consult the datasheet as it is likely named something else on a different PIC). But there is a hardware limitation on GP3, that pin can NEVER act as an output, regardless of what is in that bit position of the TRISIO register.
    So I am curious about this QBASIC that you are using for writing PIC programs.
    Can you provide a link to it?
    The PBP compiler that this forum supports is going to be VERY similar to any other "basic" language. With some minor differences that should be easy to learn.
    It is a VERY powerful compiler and well supported.
    The website for PBP is http://melabs.com
    It is a bit of an expense to purchase but well worth it
    There are some world class sofware and hardware folks that hang around here, and are very willing to help (as long as the asker shows some amount of effort before asking.)
    Most of the code examples that you will find on the PIC datasheets is going to be in assembly or machine code, not in a higher level language like basic.
    good luck and keep asking questions.
    Dwight
    Dec 2010
    FYI - QBASIC is a relatively high level language compiled (or interpreted depending on the version) to run on DOS or Windows PCs. It was written by Microsoft, and discontinued many years ago when they moved to Visual Basic. I don't think there was ever a version that compiled for PIC.
    Jan 2013
    Hi Charlie,
    As I said I learnt basic basic, soon after it came out, and have continued ever since. I've considered learning other programs, but it was hard enough to do one time, so I didn't. I've made processing equipment, automatic vehicles, and lots small stuff, and still find it amazing to have flashing lights, once I get something working. Today I have almost finished programming a remote heater start-up switch so I can warm the vehicle up, 10 mins before getting in. I compile with picsimulatoreide, and burn with pickchip2. Simple, headachy, but fun!
    Cheers, Camerart.
    Dec 2010
    Glad you've had some successes. What you may not realize is that there are dozens of versions of BASIC targeting many different processing platforms, and many different versions even for the same platform. I can name a half dozen versions for PIC alone, not to mention a few for Android, and several for Windows. Saying you use BASIC is a little like saying you speak human.
    You are currently posting on a forum dedicated to only one of those flavors - apparently not the one you are using. A major advantage of this particular version of BASIC is a large group of users that help each other, as you are discovering. Many of the other versions also have helpful communities if you can find them. Unfortunately, other than very general things, you are not likely to get much specific help for your environment from the folks here. But welcome - there are lots of great ideas here, even if there won't be specific help. And who knows... you might even find a reason to "convert" :-)
    Jan 2013
    Hi Hecler,
    I thought I had already replied, but perhaps not. Here is a link to the kind of Basic I am using: http://www.qbasic.com/
    Cheers, Camerart.
    Camerart,
    Jan 2013
    Hi Charlie,
    I did kind of realize that there are more versions of basic. I'm just glad I learnt 'QBASIC' when, and in the way I did or I would never have learnt any. I need to go into all sorts of efforts, to learn. At present I 'need' tolearn MORSE, and it's quite a challenge, for me anyway. I'm getting there.
    Cheers, Camerart. UK
    Quote Originally Posted by Charlie View Post
    Jan 2013
    SORRY!!!
    I have been informed that: I first learnt SPECTRUM BASIC,then QBASIC and now I'm using PICBASIC to program my PIC chips. It is confusing, at least for us oldies
    Cheers, Camerart.
    Dec 2010
    Getting closer... now which version of PICBASIC? Look for an *ABOUT* button.
    Jan 2013
    Hi Charlie,
    No clear answer I'm afraid, even asking my son who 'understands'. I use PICSIMULATOREIDE. This doesn't show the actual version, but has a 'basic compiler reference manual' where the programming words are. The program can then be simulated and compiled. I suppose it's been modified by Vladimir Soso, the designer. For me it's a brilliant program.
    Sorry if it's like pulling teeth, but I'm a bit limited as a computer technician
    Cheers, Camerart.
    I believe you're using the OshonSoft [url=http://www.oshonsoft.com/picbasiccompilerexamples.htmlPIC Simulator IDE integrated PIC Basic compiler[/url]. It's unfortunate that several companies calls their respective product for PIC BASIC whatever as it leads to confusion like the one we're currently having. Like I said previously, most BASIC compilers are similar but still they are ALL different from one another in some aspects.
    PIC BASIC PRO <--- The one that this forum discusses
    Swordfish PIC BASIC compiler.
    PROTON PIC Basic Compiler
    Oshon Soft PIC Basic Compiler
    mikroBasicPro for PIC from MikroE
    PIC BASIC: GCBASIC
    Great Cow BASIC for PIC (probably the same as above)
    AMICUS18 Basic (which is the same as Proton but limited device support)
    The list goes on.....and then there's the various modules running interpreted BASIC like the classic BASIC Stamps, and the ATOMs and again, they are all BASIC in one way shape or form (just like Visual Basic, GWBasic, QBasic and so on are) but they are ALL different from one another.
    Jan 2013
    PIC BASIC: GCBASIC
    Hi Henrik,
    That seems correct.
    Thanks, Camerart.
  1. first program 12f683
    By sparkness in forum mel PIC BASIC Pro
    Last Post: - 4th January 2014, 16:07
  2. 12f683 help!!!! L@@K!!!
    By thm ov3rkill in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2008, 22:46
  3. 12F683 Programmer
    By Red_Stafford in forum Schematics
    Last Post: - 2nd October 2008, 21:44
  4. Replies: 2
    Last Post: - 23rd July 2006, 08:16
  5. 12F683 Startup
    By GregK in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 00:25
