Driving LED's with PWM
Results 1 to 20 of 20
    New Jersey
    Default Re: Driving LED's with PWM
    If you have rows of 12 LEDs parallel, that means they can't be independently controlled
    for graphics, etc. You are just cycling whole rows of LEDs?
    It's not for graphics. I am testing a number and the 12 LED's are one segment of the number.
    The current can still be measured at 100% duty cycle, and as you lower the duty cycle,
    the average current should lower approximately with the duty cycle.
    Transistors have cut off slopes, so it's not extremely precise. Someone else may have to chime in about that.
    However, just because you use say 50% duty cycle, the fact remains that the row of LEDs and hardware to drive
    them are using the same current for half of the time, and no current for the other half of the time.
    That's if you negate a little error for the actual switching on and off, but I don't know exactly what the cost is there.
    I did some testing tonight but things still aren't clear for me. I will post the results below and maybe someone can derive something useful from this information. Brightness (how the user views it) is the ultimate test so I put a photocell on top of one LED and wrapped it in black electrical tape. I took random measurements with a bunch of tests using only PWM and the other using straight DC with a resistor. For clarification, the lower the resistance the higher the brightness.
    LED'S ON	ON TIME	OFF TIME	CDS Resistance	DC Current	AC Current	Resistor
    1---------	5uS	        740 uS	92.2 Ohms	         36.4 mA	XXXXXXXXX	No	XXXXXXXXX
    2---------- 5uS	        740 uS	94.2 Ohms	         41.3 mA	XXXXXXXXX	No	XXXXXXXXX
    3---------- 5uS	        740 uS	98.3 Ohms	         52.6 mA	XXXXXXXXX	No	XXXXXXXXX
    1+12 LED's	5uS	        740 uS	150.4 Ohms	         49.9 mA	189.3 mA	        No	XXXXXXXXX
    1+12 LED's	5uS	        640 uS	141.2 Ohms        	 57.2 mA	214.2 mA	        No	XXXXXXXXX
    1---------- 5 uS	        940 uS	118.4 Ohms       	 27.2 mA	XXXXXXXXX	No	XXXXXXXXX
    1---------- 5 uS	       1140 uS	128.6 Ohms	          23.5 mA	XXXXXXXXX	No	XXXXXXXXX
    2---------- 5 uS	       1140 uS	133.5 Ohms	         29.6 mA	XXXXXXXXX	No	XXXXXXXXX
    3---------- 5 uS	       1140 uS	133.6 Ohms	         37.2 mA	XXXXXXXXX	No	XXXXXXXXX
    1+12 LED's	5 uS	       1140 uS	194.8 Ohms    	33.4 mA	159.7 mA	        No	XXXXXXXXX
    1+12 LED's	5 uS	        1240 uS	203 Ohms	        31.3 mA	154.6 mA	        No	XXXXXXXXX
    1---------- 5 uS   	1240 uS	127 Ohms	         21.5 mA	XXXXXXXXX	No	XXXXXXXXX
    1+12 LED'S	100	0---------	         109.2 Ohms	94.2 mA	XXXXXXXXX	Yes	29.6 Ohms
    1+12 LED'S	100	0---------	         117.3 Ohms	79.9 mA	XXXXXXXXX	Yes	35.6 Ohms
    1+12 LED'S	100	0---------	         136.1 Ohms	64.7 mA	XXXXXXXXX	Yes	44.5 Ohms
    1+12 LED'S	100	0---------	         159.4 Ohms	49.3 mA	XXXXXXXXX	Yes	59.3 Ohms
    1+12 LED'S	100	0---------	         201.6 Ohms	33.5 mA	XXXXXXXXX	Yes	89 Ohms
    1+12 LED'S	100	0---------	         310.2 Ohms	17.1 mA	XXXXXXXXX	Yes	178 Ohms
    I don't see much of a difference between PWM and using a resistor.
    Pretty much the same thing I observed.
    Brightness requires current, I don't think you can get around that.
    Maybe if you start tinkering with transformers?
    New Jersey
    Is this statement correct?
    Even though the currents are similar, using PWM without a resistor must be more efficient since a resistor isn't being heated.
    Another thing that doesn't make sense is the non-linear curve in current when adding diodes onto the PCB. One LED consumes 30mA but two doesn't equal 60.
    Oct 2011
    East Coast USA
    An LED cannot have more than its forward bias voltage across it. For an old red LED that voltage is about 1.6 volts. Sacrifice one by driving one with a variable power supply. It will start lighting at a little over 1.5 v. It will be brightest at 1.6v. Only when it burns out will the voltage go much higher than that.
    In a circuit, the current is limited by the impedance (resistance) of the circuit driving it. If you drive the LED directly from a i/o pin, the current will be limited by the impedance of the output circuit. The output transistor or FET will act as the resistor and limit the current to some value.
    There are two different limits on the current through the LED, the maximum instantaneous current and the max average current. If you exceed the first, the LED will fail immediately. If you exceed the second, it will overheat and die more slowly. There should be a resistor to limit the current to below the max instantaneous current. You can then use PWM to stay below the max average current.
    The instantaneous current through the LED can be calculated using i = e / r where r equals the sum of the impedance of the driver plus any external resistor. Heat will be lost by the voltage drop across the driver transistor and the external resistor.
    Quote Originally Posted by Christopher4187 View Post
    ...Another thing that doesn't make sense is the non-linear curve in current when adding diodes onto the PCB. One LED consumes 30mA but two doesn't equal 60.
    I have a similar problem. I'm designing panels for my residential alarm system and I'm kinda overwhelmed by the possible maximum current. A LOT of LEDs could potentially be on at the same time (I'm using solid strand 24 AWG telephone wire with 12V 7Ah battery backup).
    I started with LCDs, but these panels are not only for the house where it's warm, it's also for the garage (worried about cold and humidity).
    Thanks!
    Just went through the 1st, great stuff!
    Didn't download the dice yet. I want to see what I can do on my own first.
    Robert The Very Happy Camper
    New Jersey
    If it's a panel inside then you could supply 1-3mA per LED. There's no reason to supply the maximum amount of current since you won't have an audience to view them and they are inside. I recently used Screenmaster LED's and at 1mA they were really bright. I wish I had your problem. My LED scoreboard is outside and the sunlight hits it. Needless to say the LED's have to be really bright.
    If it's a panel inside then you could supply 1-3mA per LED. There's no reason to supply the maximum amount of current since you won't have an audience to view them and they are inside. ...
    I'll be using surface-mount LEDs that I have on hand (got some greens, yellows and reds). I think they require somewhere between 15-20mA to be reasonably visible in daylight inside the house (some panels could be in full sunlight).
    I'll be making my own light chimneys with clear liquid plastic from Smooth-On.
    Finished preliminary testing today, very low current is achievable, I just have to improve code logic and efficiency:
    http://www.picbasic.co.uk/forum/showthread.php?t=18906
    Of course none of the colours I have are of the same brightness so some tweaking of the resistors will be necessary.
  1. control 60 tri-color LED's
    By MOUNTAIN747 in forum General
    Last Post: - 15th September 2011, 23:30
  2. shared data lines for LCD and LED'S?
    By nomad in forum mel PIC BASIC Pro
    Last Post: - 14th February 2009, 04:37
  3. Scolling LED's
    By Melanie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2008, 23:28
  4. Killing blue led's
    By Steve_88 in forum Off Topic
    Last Post: - 31st January 2008, 02:37
  5. Driving a Voltage Regulator with PWM
    Last Post: - 27th June 2007, 13:14
