Configuration bits and timing
Results 1 to 7 of 7
Threaded View
  1. #6
    Jun 2011
    Default Re: Configuration bits and timing
    I didn't see ANSEL in the p18f26k80.h file.
    So I tried the following using the ANCON configuration registers and it seems to work;
    ADCON0 = %00000000 ;P364 A/D CONTROL REGISTER 0
    ADCON1 = %00000000 ;P365 A/D CONTROL REGISTER 1
    ADCON2 = %00000000 ;P366 A/D CONTROL REGISTER 2
    ODCON = %00000000 ;P179 PERIPHERAL OPEN-DRAIN CONTROL REGISTER
    ANCON0 = %00000000 ;P369 A/D PORT CONFIGURATION REGISTER 0***
    ANCON1 = %00000000 ;P369 A/D PORT CONFIGURATION REGISTER 1***
    CM1CON = %00000000 ;P378 COMPARATOR CONTROL x REGISTER
    CM2CON = %00000000 ;P378 COMPARATOR CONTROL x REGISTER
    Thanks for pointing me in the right direction.
    Last edited by RayL113; - 17th November 2012 at 05:07. Reason: Forgot to say Thanks
  1. RC5 code for infrared receiver
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 11th January 2017, 12:34
  2. 12F683 serout timing
    By Hobie Cat in forum mel PIC BASIC Pro
    Last Post: - 21st December 2009, 16:57
  3. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
