Configuration bits and timing
Results 1 to 7 of 7
    Default Re: Configuration bits and timing
    Open up the datasheet and take a look at the ADC section - especially the ANCON register. It says:
    The ANCONx registers are used to configure the operation of the I/O pin associated with each analog channel. Clearing an ANSELx bit configures the corresponding pin (ANx) to operate as a digital only I/O.
    Cool device that, 12bit ADC with differential input, two internal references - hadn't noticed it before.
    Jun 2011
    I've tried;
    ANSEL = $00
    ANSEL = 0
    ANSEL0 = 0
    and get "ERROR Line 30: Syntax error.30: Syntax error 30: Syntax error"
    Any suggestions on the correct way to enter this setting in this new chip?
    Jun 2011
    I didn't see ANSEL in the p18f26k80.h file.
    So I tried the following using the ANCON configuration registers and it seems to work;
    ADCON0 = %00000000 ;P364 A/D CONTROL REGISTER 0
    ADCON1 = %00000000 ;P365 A/D CONTROL REGISTER 1
    ADCON2 = %00000000 ;P366 A/D CONTROL REGISTER 2
    ODCON = %00000000 ;P179 PERIPHERAL OPEN-DRAIN CONTROL REGISTER
    ANCON0 = %00000000 ;P369 A/D PORT CONFIGURATION REGISTER 0***
    ANCON1 = %00000000 ;P369 A/D PORT CONFIGURATION REGISTER 1***
    CM1CON = %00000000 ;P378 COMPARATOR CONTROL x REGISTER
    CM2CON = %00000000 ;P378 COMPARATOR CONTROL x REGISTER
    Thanks for pointing me in the right direction.
    Last edited by RayL113; - 17th November 2012 at 05:07. Reason: Forgot to say Thanks
    That's because there is no ANSEL register in the 26K80. The register is called ANCONx.
  1. RC5 code for infrared receiver
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 11th January 2017, 12:34
  2. 12F683 serout timing
    By Hobie Cat in forum mel PIC BASIC Pro
    Last Post: - 21st December 2009, 16:57
  3. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
