Pic16f1826
Results 1 to 8 of 8
Thread: Pic16f1826
    Default Pic16f1826
    Anyone try to program this chip with MicroCode plus and MPASM? I am getting error messages saying unknown processor and can't find pic16f1826.inc and a bunch more error messages. The pic16f1826 shows up in the microcode window and the processor is supported according to the PBP web site? I'm using PBP 2.6 and MPASM 8.5 everything works with PIC16F88 any ideas. I'm pretty simple so go easy on me. thanks
    1st you need to modify the 16F1826 & 1827.bas files like shown here: http://melabs.com/support/pbpissues.htm
    Here's a thread showing a few more edits you may need also: http://www.picbasic.co.uk/forum/show...4227#post84227
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default Thank You
    Just wanted to thank everyone and -Bruce at rentron.com
    All seems to work now just have to figure out how all the PWM's work together and try microchips ideas thanks again!
    Mar 2005
    CROATIA
    Default Re: Thank You
    I'm trying to migrate from 16f628a to 16f1827, program is using 2 DT instant interrupt sources;(int=gsm (rb0) modem ring and on change coin receiver (rb4,5,6,7))
    628 had only 4 on change pins, and now 1827 have more on change which now changed name to IOC, my question is
    RB0 now share 2 interrupt INT and IOC, i read few time datasheet and didn't find some kind of mask to disable IOC on rb0 to live
    INT do old job, which interrupt will fire rb0 if both interrupt wait action ? and how to mask/route IOC only to needed pins ?
    is it maybe only way put all to IOC and in int-routine determining who fired int.... 2 interr. are more logic and easier way but if no joy.......
    i think this is question for microchip forum, but here often answers have more sense
    While I'm looking at the datasheet to see if I can help, did you make sure there are no analog features enabled on B0?
    If you don't know, Darrel has made a neat tool to make sure all pins are digital. Details here:
    http://www.picbasic.co.uk/forum/showthread.php?t=11100
    Just throwing ideas out:
    • REGISTER 12-1: APFCON0: ALTERNATE PIN FUNCTION CONTROL REGISTER 0 ... This register might be worth a look.
    • 12.3.4 PORTB FUNCTIONS AND OUTPUT PRIORITIES ... Here you see what function will work in what priority.
    Sorry, that's all I could find searching for RB0 in the datasheet.
