Can PBP understand negative numbers?
Results 1 to 4 of 4
    Feb 2005
    Bellevue
    Angry Can PBP understand negative numbers?
    I have a routine that is incrementing or decrementing 1 time each pass. It reads a milibar value(dec_mb) every second. Then it compares this to the last reading(last_mb) to see if it is going up or down. The value inc_mb then holds a cumulative value, but it can be negative.... After 10 loops it trys to tell me what the trend is - it does not work, and my Inc_mb which should be a value of -10 to 10 shows '255' which must mean a negative number breaks PBP??
    So I can see an average move over 10 seconds, I wrote the following:
    if Dec_mb > last_mb then
    inc_mb=inc_mb+1
    if Dec_mb < last_mb then
    inc_mb=inc_mb-1
    mb_count = mb_count+1
    if mb_count > 10 then
    if inc_mb >= 6 then
    LCDout " R+",#inc_mb
    if inc_mb > 2 and inc_mb < 6 then
    LCDout " R ",#inc_mb
    if inc_mb > -2 and inc_mb <= 2 then
    LCDout " S ",#inc_mb
    if inc_mb <= -2 and inc_mb >= -6 then
    LCDout " F ",#inc_mb
    if inc_mb < -6 then
    LCDout " F+",#inc_mb
    It always tells me it is 'F+', even when the value is '0'.. it should be telling me 'S' there..
    Arggghhh..
    PBP don't handle +/- results directly as VB or else PC language. You have to refer to the CARRY or Z flag of the STATUS register. OR
    If NewResult>OldResult then Sign=Negative
    there's a ton of different way to do this task... One idea here why not using a range of 20. If between 0-10 => negative 10-20 Positive
    Puerto Rico
    Smile - values (example)
    PumpMath = (Throttle - ThrottleMin) * 100 / RadioScalefactor
    if (PumpMath > 101) or (PumpMath < 0) then
    PumpMath=0
    if (CurrentStep + 1 < PumpMath) and (PumpMath < 100) Then
    IF (CurrentStep < PumpMath) Then
    CurrentStep = CurrentStep + 1
    EndIF
    IF (CurrentStep > PumpMath) Then
    CurrentStep = CurrentStep - 1
    EndIF
    if (CurrentStep - 1 > PumpMath) and (PumpMath >0) Then
    EndIF
    EndIF
    Feb 2005
    Bellevue
    Smile
    THANKS! I think I figured it out!
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. Replies: 4
    Last Post: - 15th April 2009, 02:54
    Last Post: - 2nd May 2006, 20:01
  4. Multiplying large numbers
    By jhonea1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2006, 18:41
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
