Hi Jan,
I don't understand.....
The AD654 is a Voltage-to-Frequency converter, it takes an analog voltage in and outputs a frequency which is what you're feeding your servodrive, correct?
Using the HPWM command and a simple RC lowpass filter will give you an analog voltage from 0-Vcc for a duty cycle of 0-100% and as far as I can see the AD654 should be able to "get down" to 0kHz with 0V input signal. Are you saying that the output frequency of the AD654 is not reaching 0Hz when the input voltage is 0V?
Are you aiming to get rid of the AD654 feed the servo-drive directly with the PIC?
Can you upload a schematic? What servo drive are you using?
