Microcode Studio Plus
Results 1 to 8 of 8
    Default Microcode Studio Plus
    I know this is a separate product from an unrelated vendor, but maybe he reads this forum, so here goes.
    I wish, I wish, I wish, Microcode Studio Plus, had an option (read check box ) to enable version control, as separate original files at compile time. If it did, I might have a little more hair.
    Default Re: Microcode Studio Plus
    I have a habit of saving files with a version suffix.; ie. TESTv1.BAS.
    I do that with just about anything that I edit.
    Nov 2007
    West Covina, CA
    I do the same thing too. But wouldn't it be nice to have a "running" list of the compiled file so all your changes can be reviewed when you screw up?
    At least that's what I think Archangel is talking about.
    Louie
    Quote Originally Posted by LinkMTech View Post
    you screw up?
    Hey, Louie, how did you guess my middle name ?
    That's what I want, to generate a unique file name every time it compiles.
    Joemessedup.bas
    Joemessedup1.bas
    Joemessedup2.bas . . .
    Joemessedup247.bas
    I have programs which do this if they encounter an existing file name that's exactly the same as the one I am saving. Down them all is one and I also recommend it too.
    Yup, I'd appreciate that feature too.
    Hi guys,
    Look up this old thread: http://www.picbasic.co.uk/forum/showthread.php?t=8960
    It does pretty much what you need. And thankfully, the serializer utility discussed in that thread is also still available online.
    Hope this helps!
    Nov 2007
    West Covina, CA
    Thanks for the link ardhuru.
    Eager to try it out has me trying find where to put the "vclsmp50.bpl" file.
    I extracted the three files to one folder and tried to open the application but won't because "Vcl50.bpl" was not found.
    Alain mentioned this file should be copied to the utility Directory but that's where I got lost and just glad to make it out alive.
    Louie
    Nov 2007
    West Covina, CA
    Okay got it running with info from Alain on other thread:
    Also, Do not forget to add :
    VCL50.BPL
    VCLX50.BPL
    in the utility Directory ...
    those can be found on the WEB ...
    Then just add INCLUDE " C\...\Serinfo.bas" to the top of the BASIC file :
    Didn't get it working completely but can tell it's not what I thought it would be. Seems to only keep a running "counter", with other info, of the compiled file.
    Thought it would keep a list of all the same name files, same as "Save As", like Joe mentioned.
    Unless! I'm doing something wrong again...
    Louie
  1. microcode studio
    By cable tech in forum mel PIC BASIC
    Last Post: - 28th September 2011, 16:53
  2. using MicroCode Studio
    By Max_Gauss in forum mel PIC BASIC Pro
    Last Post: - 8th September 2011, 19:04
  3. Microcode studio
    By Stargazer3141 in forum General
    Last Post: - 28th January 2011, 22:49
  4. microcode studio plus
    By c_moore in forum General
    Last Post: - 26th July 2010, 10:45
  5. MicroCode Studio Plus
    By ozarkshermit in forum General
    Last Post: - 30th December 2009, 23:27
