does this work?
Results 1 to 9 of 9
Thread: does this work?
    igor@24's Avatar
    igor@24 Guest
    Sougata, Mister_e, Thank you!
    I want to learn and learn ...
    This is the best forum i have ever seen.
    I will check my mail now.
    igor@24's Avatar
    igor@24 Guest
    Hi! I have made another programme. Sample files (PBP compiler) helped me doing that.
    char var byte
    start: Hserout ["http://www.igorbogetic.co.sr", 13, 10]
    slanje: Hserout [char]
    lcd: Lcdout $fe, 1
    Lcdout "Hi!"
    Pause 500
    Lcdout $fe, 1
    Lcdout "Visit http://www.igorbogetic.co.sr"
    Pause 500
    LED: High 0
    Pause 200
    Low 0
    Pause 200
    SO con 0
    B con 5
    N2400 con 4
    B0 var byte
    B0 = 0
    loop: Button B,1,10,5,B0,0,notp
    Goto lcd
    Goto LED
    Goto slanje
    notp: Serout SO,N2400,[#B0,13,10]
    Pause 100
    Goto loop
    Can that work? If there is any error please write!
    Thank you on your help.
    Igor
    when posting, let us know wich pic you're using, the crystal speed. and then we can give a hand on that.
  1. pls help me verify my code not work, why???
    Last Post: - 18th January 2010, 10:19
  2. Can't get POT work on P12f675 - Newbie
    By berslan in forum mel PIC BASIC Pro
    Last Post: - 26th March 2008, 22:22
  3. How to set ICD-2 clone to work with PBP?
    By G-R-C in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 03:50
  4. blink.bas help cant make any 18f's work
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 13th December 2004, 22:28
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
