does this work?
Results 1 to 9 of 9
Thread: does this work?
    Hi Igor,
    Yes, lcdout "Hello" would work with PBP.
    However, the rest of your program appears to be written for PROTON+
    A better place to ask your question would be at ...
    http://www.picbasic.org/forum/
    Best regards,
       Darrel
    igor@24's Avatar
    igor@24 Guest
    Thumbs up
    Darrel, thank you a lot!
    But now I have more questions?
    1. What is PROTON+ (programming language?) ?
    2. What is this for and how to use it :
    Expi+
    Expo
    LookUp &LookDown
    Beep (beep sound?)
    (how to use it - i mean to write me something like this: LookDown something something...)
    Is this code right:
    counter var word
    pulse var word
    for counter = 1 to 50
    gosub walk_left
    gosub walk_right
    next
    Sound 35,120
    walk_left:
    for pulse = 0 to 10
    pulsout 15, 820
    pause 20
    next
    for pulse = 0 to 10
    pulsout 14, 600
    pause 20
    next
    Beep 35
    walk_right:
    for pulse = 0 to 10
    pulsout 15, 680
    pause 20
    next
    for pulse = 0 to 10
    pulsout 14, 900
    pause 20
    next
    lcdout "Hello"
    lcdout "visit http://www.igorbogetic.co.sr"
    Yes Proton is a programming language. It is very similar to PicBasic Pro, with some added functionality.
    You can find out everything about it at
    http://www.picbasic.org/proton_compiler.php
    I have no idea what Expi+ and Expo are. But for the rest, download the user guide at the above link.
    Darrel
    Feb 2005
    Kolkata-India
    Thumbs up Hi igor,
    It seems that you are learning VB and C++ and having great fun. You dropped into this forum and it interested you. I will try to explain a little bit on microcontroller (the PIC micro) and what PICBasic or Proton is through a personal email. If you need to have a taste of the same. You will need a few tools to build the electronics and have more fun. I am on very tight schedules but would love to hep you get into microcontrollers.
    Sougata
    Igor,
    i wish one day i could go back in time and learn all of what you already and will learn with the age you have. You can't imagine how many future job are waiting for you. In the past, computer language and MicroController was really different than now. I remind really well to save/load my program on/from an audio tape... sorry fellows here if i make you feel older now ;o)
    Welcome to the PIC world and good luck!
    igor@24's Avatar
    igor@24 Guest
    Sougata, Mister_e, Thank you!
    I want to learn and learn ...
    This is the best forum i have ever seen.
    I will check my mail now.
    igor@24's Avatar
    igor@24 Guest
    Hi! I have made another programme. Sample files (PBP compiler) helped me doing that.
    char var byte
    start: Hserout ["http://www.igorbogetic.co.sr", 13, 10]
    slanje: Hserout [char]
    lcd: Lcdout $fe, 1
    Lcdout "Hi!"
    Pause 500
    Lcdout $fe, 1
    Lcdout "Visit http://www.igorbogetic.co.sr"
    Pause 500
    LED: High 0
    Pause 200
    Low 0
    Pause 200
    SO con 0
    B con 5
    N2400 con 4
    B0 var byte
    B0 = 0
    loop: Button B,1,10,5,B0,0,notp
    Goto lcd
    Goto LED
    Goto slanje
    notp: Serout SO,N2400,[#B0,13,10]
    Pause 100
    Goto loop
    Can that work? If there is any error please write!
    Thank you on your help.
    Igor
  1. pls help me verify my code not work, why???
    Last Post: - 18th January 2010, 10:19
  2. Can't get POT work on P12f675 - Newbie
    By berslan in forum mel PIC BASIC Pro
    Last Post: - 26th March 2008, 22:22
  3. How to set ICD-2 clone to work with PBP?
    By G-R-C in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 03:50
  4. blink.bas help cant make any 18f's work
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 13th December 2004, 22:28
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
