is it possible?
Results 1 to 2 of 2
Thread: is it possible?
    May 2005
    Talking is it possible?
    Hi it's me again with my strange question.
    Here is the question.
    i have pic 16F877 connected to 2 x 16F628 and 2 x (16x2) LCD and a keyboard
    i want to use pic 16F877 as master controller connected with PC (1. connection) and try to use another LCD controlled by 16F628 again connected with 16F877 (2. connection) and the last connection again connected with 16F628 (3. connection)
    in the picture u can see the shema of the question.
    How can i use HSERIN and HSEROUT commands to control them?Is there any solution to control them.If any body could give me an example i will really be glad.Thanks for reading my strange question.
    Asking is not a shame but not learning is a SHAME!!!
    O.K that's not strange and i see one improvement that should be done first to make it simple.
    About those LCDs, you can control more than 1 LCD with the same PIC, you just need few external parts. see the following thread, everything is really well explain. code and schematic are included
    http://www.picbasic.co.uk/forum/showthread.php?t=626
    so now you save one PIC, code, money, time....
    Now, about the other 16F628... what will be his purpose, do you want to have bidirectional communication, i mean, do you want that the master send a command then receive the according answer from the 16F628???
    If so, kepp the HSERIN/HSEROUT for your PC communication and use SERIN/SEROUT/SERIN2/SEROUT2 to talk to that device.
        '    This is the snip of the Master PIC16F877
        '    This will send a byte to the PIC16F628 and
        '    waiting for a reply.  If there's no reply
        '    after 2 second it will display an error
        '    message to the LCD.
        SerialOUTToPIC16F628  var PORTC.0
        SerialINFromPIC16F628 var PORTC.1
        SentByPIC16F628       var byte
        SendMeBeer            con 0    ' command bytes
        SendMeFruit           con 1    '     to be
        SendMeCash            con 2    '     send
        T2400                 con 396  ' used for baudrate=2400
        TimeoutDelay          con 2000 ' used for timeout=2000 mSec=2 Sec
        HIGH SERIALOUTTOPIC16F628      ' For safety sake and avoid to send
                                       ' garbage at the first time
    start:
        pause 2000   ' LCD start-up delay AND future LCD message duration
        lcdout $fe,1 ' Clear LCD screen
        serout2 serialouttopic16f628 ,T2400,_       ' send command byte to
                [sendmebeer]                        ' the external PIC16F628
        serin2  serialinfrompic16f628,T2400,_       ' waiting for
                timeoutdelay, DisplayErrorMessage,_ ' the external
                [sentbypic16f628]                   ' PIC16F628 answer
                ' jump to different routine
                ' depending of the
                ' SentbYPIC16F628 value
                branch sentBYpic16f628,[Budweiser,_ ' when = 0
                                        MolsonDry,_ ' when = 1
                                        SmirnoffIce]' when = 2
                goto start
                ' Timeout occur, display
                ' the error message
                DisplayErrorMessage:
                                    lcdout         "Looks like my",_
                                           $fe,$c0,"buddy sleep!!"
                                    goto start
    BudWeiser:
        lcdout "Let's drink a ",$fe,$C0,_
               "Budweiser Barrel"
        goto start
    MolsonDry:
        Lcdout "lezzz dwwwwrank",$fe,$c0,_
               "a MolsonDry pot"
        goto start
    SmirnoffIce:
        lcdout "ZZZzzzzzzZZ i i",$fe,$c0,_
               "loowve you....."
        goto start
        '    This is the code snip for the PIC16F628
        '    This will wait for a PIC16F877 command request
        '    and return a byte value.
        SerialOUTToPIC16F877  var PORTB.0
        SerialINFromPIC16F877 var PORTB.1
        SentByPIC16F877       var byte
        SendToPIC16F877       var byte
        Budweiser             con 0    ' command bytes
        MolsonDry             CON 1    '     to be
        SmirnoffIce           CON 2    '      send
        high SERIALOUTTOPIC16F877      ' For safety sake and avoid to send
    start:
        serin2  serialinfrompic16f877,t2400,_ ' waiting for
                [sentbypic16f877]             ' the external
                                              ' PIC16F877 answer
        branch sentbypic16f877,[SendMeBeer,_  ' =0
                                SendMeFruit,_ ' =1
                                SendMeCash]   ' =2
        goto start
    SendMeBeer:
        sendtopic16f877=budweiser ' open the fridge and choose your beer
        goto SendData             ' send it to master
    SendMeFruit:
        ' do according stuff
        goto SendData
    SendMeCash:
        goto SendData
    SendData:
        serout2 serialouttopic16f877,t2400,[sendtopic16f877]
        goto start
    Above are just rough example. Should be enough to start.
    For the PC communication you can use the internal USART module or still use SERIN/SEROUT stuff. As i remind, that part you already know how to play with in PIC amd in VB.
    for your keyboard... hard to know wich kind you use but if it's a matrix one, you can find code example almost everywhere... Click here to download the Melabs keyx.bas file
