PBP wish list.....
Results 1 to 8 of 8
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default PBP wish list.....
    It would be real beaut if there were 2 additional functions, which would suit a lot of stuff I am doing:
    1. DTMF decoding and converting to ASCII
    2. FREQIN to about 10kHz
    As I say, these would suit me a whole lot.
    Pinckney, Michigan
    32-bit interger math (longs) would be very nice. DIV32 helps but "real" longs would be very nice.
    Dec 2003
    Wichita KS
    Hello Muddy,
    Your frequency can easily be calculated by using Pulsin in a subroutine...This has not been tested, but the idea is there. I wrote one a long time ago for RPM on a 2 stroke airplane engine.
    routine:
    Pulsin Pin1, 1 ,Pos 'measures the positive Pulse
    Pulsin Pin1, 0, Neg 'measures the negative Pulse.
    Wavelength/cycle=Pos + neg 'Adds them together for the full length
    Frequency=1000/Wavelength '(in ms)
    Frequency=1000000/Wavelength '(in us)
    return Frequency
    DTMF is a frequency...Thus the above routine can measure the frequence of the DTMF and tell you which number you pressed...
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Sep 2005
    Campbell, CA
    32 bit integers. Better interrupt support would be nice too.
    Quote Originally Posted by Dwayne
    Hello Muddy,
    routine:
    return Frequency
    Dwayne
    Hi, Dwayne
    Just a little example of what you wrote ... also applied to a model RPM Meter !!!
    DTMF might be a little trickier as there are TWO mixed frequencies ... but there are cheap and excellent DTMF decoders on the market ...
    Why re-invent the wheel ???
    Default Simple wish... far at the bottom of the to-do list
    Even if it's not important.. it could be interesting to have
    Hardware and Software block definition
             '    Lcd
             With LCD
                  Data = PORTA,0    ' Set data pin of LCD to
                                    ' PORTA.0-PORTA.3
                  RS = PORTB,4      ' Set RS bit of LCD to
                                    ' PORTB.4
                  E = PORTB,5       ' Set E bit of LCD to
                                    ' PORTB.5
                  LINES = 4         ' 4 Lines LCD
                  COMMANDUS = 2000  ' Command delay time in uSec
                  DATAUS = 50       ' Data delay time in uSec
                  EndWith
    Same for all other function like DEBUG, HPWM, HSERIN....
    I/O Alias block
    Alias PORTA
         .0 = SCL
         .1 = SDA
         .2 = StatusLED
         EndAlias
    Variable type block
    BYTE
        CounterA
        Discard
        BlahBlah
        EndBYTE
    martarse's Avatar
    martarse Guest
    Default DTMF decoder wery hard to find!
    Hello alain,
    DTMF decoders are very hard to find. I know there are many models on the market but they seem to be unavailable.
    Clare, Motorola, SDI, TI and some others manufacturers have stated the end of manufacture for this part!
    Zarlink are another company that make this part, but they are not interested to sell it for an order under 10000 units.
    I think a function like DTMF Decoding would be very interesting in the next release of PBP.
    salut!
    Martin
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. PBP List file???
    By MOUNTAIN747 in forum General
    Last Post: - 28th February 2010, 19:48
  3. List of instructions used in PBP ?
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2007, 11:22
  4. PBP Editor Wish List:
    By blainecf in forum PBP Wish List
    Last Post: - 12th July 2006, 21:07
  5. PBP Wish List
    By Radiance in forum PBP Wish List
    Last Post: - 1st February 2005, 17:30
