Can not decode properly IR remote code.
Results 1 to 11 of 11
    Default Re: Can not decode properly IR remote code.
    Thanks, but your code lacks some commands as I can see, like:
    OSCCON = %01110111
    to set OSC clock to 8mhz
    And it is quite interesting, if it's possible to decode air conditioner remote codes? they are very long and very weird
    Aug 2008
    Portugal
    OSCCON = %01110111
    You cannot assume that just by see "DEFINE OSC 8", because he can be using an external osc. You can only assume that, it he had post the config fuses.
    One more thing, about this
    There's nothing much to post in schematic, the receiver is hooked as it should, GND goes to GND, VDD goes to VDD, and OUT is connected to PORTC.4
    What's the reference of your IR receiver? Because some need a pull up resistor, when your are not using it.
    Thanks and Regards;
    Gadelhas
    I've solved the problem, but code is quite weird
    Code looks like this:
    MAIN:
    PULSIN FLASH,1,SOMEVAR
    IF SOMEVAR<50 AND SOMEVAR >20 THEN GOTO KOUNT
    GOTO MAIN
    KOUNT:
    INCREMENT=INCREMENT+1
    IF FLASH=1 THEN POS=POS+1 ELSE NEG=NEG+1
    IF INCREMENT>1000 THEN GOTO COMPLETE
    GOTO KOUNT
    COMPLETE:
    IF POS>100 AND POS<300 AND NEG>1000 AND NEG<3000 THEN GOSUB JOB:
    POS=0:NEG=0:INCREMENT=0
    GOTO MAIN
    JOB:
    TOGGLE RELAY1
  1. remote code learning
    Last Post: - 21st February 2021, 15:38
  2. Using Walter's Servo PWM encode / decode code
    By NickMu in forum mel PIC BASIC Pro
    Last Post: - 1st November 2012, 23:17
  3. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  4. Hitachi remote code
    By aa222k in forum mel PIC BASIC Pro
    Last Post: - 26th October 2008, 23:20
  5. IR decode problem "hitachi TV remote"
    Last Post: - 13th March 2006, 15:29
