Can not decode properly IR remote code.
Results 1 to 11 of 11
    Aug 2008
    Portugal
    Default Re: Can not decode properly IR remote code.
    I don't understand why are you using serin????!?!?
    IR protocol doesn't work with serin, you must create code to read it. By looking at the picture it seems to me that the protocol its NEC, so use code to decode NEC protocol. If you do a search in the forum you will find some code.
    Thanks and Regards;
    Gadelhas
    Yes, I found that it is nec, and tried to take code from here:
    http://www.picbasic.co.uk/forum/showthread.php?t=15368
    and modified it to my needs:
    Include "modedefs.bas"  ' Include serial modes
    'DEFINES FOR LCD PORTS
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1500
    DEFINE LCD_DATAUS 44
    define osc 4
    ADCON1=%00000110 'CONFIGURE PORT A AS DIGITAL
    'TRISA=1 'CONFIGURE PORT A AS INPUT
    low TRISB
    LOW TRISC
    LOW TRISA
    Leader VAR WORD     ' will be up to 900 for a 9mS leader pulse
    BtnVal VAR BYTE[32] ' holds 32 pulse results
    DByte1 VAR BYTE     ' address byte
    DByte2 VAR BYTE     ' inverse of address byte
    DByte3 VAR BYTE     ' command byte
    DByte4 VAR BYTE     ' inverse of command byte
    X      VAR BYTE     ' loop count
    LCDOUT $FE, 1,  "test "
      PULSIN PORTC.4,0,Leader  ' leader pulse is ~9mS low-going
      IF Leader < 850 THEN Main
      FOR X = 0 TO 31          ' grab 32 incoming pulses
          PULSIN PORTC.4,1,BtnVal(X) ' now measuring high-going pulse widths
      NEXT X
      ' now we'll decode 4 bytes from 32 pulses
      FOR X = 0 TO 7               ' sort 1st 8 pulses
          IF BtnVal[X] > 150 THEN  ' > 150 x 10uS = > 1.5mS pulse period
             DByte1.0[X]=1
             DByte1.0[X]=0
      NEXT X
      FOR X = 8 TO 15              ' sort 2nd 8 pulses, etc....
             DByte2.0[X-8]=1
             DByte2.0[X-8]=0
      NEXT X
      FOR X = 16 TO 23
             DByte3.0[X-16]=1
             DByte3.0[X-16]=0
      NEXT X
      FOR X = 24 TO 31
             DByte4.0[X-24]=1
             DByte4.0[X-24]=0
      NEXT X
    LCDOUT $FE, 1, #dbyte1, " ", #dbyte2, "    "
    LCDOUT $FE, $C0,#dbyte3, " ", #dbyte4, "    "
      PAUSE 1000
      GOTO Main
    The problem is, it still does not works. It displays "0" when I press a key on remote. Sometimes, it will display something, like 4 or 170, but it never matches the key pressed and never repeats.
    Aug 2008
    Portugal
    I didn't look at the code, because i'm at work, but you should post your schematic too!
    Thanks and Regards;
    Gadelhas
    There's nothing much to post in schematic, the receiver is hooked as it should, GND goes to GND, VDD goes to VDD, and OUT is connected to PORTC.4
    Aug 2011
    Guadalajara, México
    I never tried NEC protocol before, but Sony SIRC has been worked flawlessly to me and it's very easy to decode with minimal resources, you should give a try:
    http://www.picbasic.co.uk/forum/cont...next-project!!
    Regards.
    My English doesn't sucks, it's just fugly...
  1. remote code learning
    Last Post: - 21st February 2021, 16:38
  2. Using Walter's Servo PWM encode / decode code
    By NickMu in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2012, 00:17
  3. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
  4. Hitachi remote code
    By aa222k in forum mel PIC BASIC Pro
    Last Post: - 27th October 2008, 00:20
  5. IR decode problem "hitachi TV remote"
    Last Post: - 13th March 2006, 16:29
