Can not decode properly IR remote code.
Results 1 to 11 of 11
    Default Can not decode properly IR remote code.
    Hello.
    I want to use the IR remote in my project. I got the 38khz receiver from STB, and it's remote control. The code I'm using is as follows:
    mand VAR word
    vice VAR word
    pice var word
    cice var word
     SERIN irPin,N2400,vice,mand,pice,cice
     LCDOUT $FE,$C0,#vice, " ", #mand," ",#pice, "  ", #cice, "  "
    The problem is, that codes being read, are almost always different, but remain within same range according the distance of remote to receiver. Say, at 5cm, when pressing "1" button, I'll get reading in range of 240-250, but at 50cm, reading with same button will be 40-50. Even more fun is the fact, that when checked with scope, the signal on sensor output is the same. Here I attach the screenshot from scope.
    What I'm doing wrong?
    http://www.freeimagehosting.net/newuploads/yqv37.jpg
    Aug 2008
    Portugal
    Default Re: Can not decode properly IR remote code.
    I don't understand why are you using serin????!?!?
    IR protocol doesn't work with serin, you must create code to read it. By looking at the picture it seems to me that the protocol its NEC, so use code to decode NEC protocol. If you do a search in the forum you will find some code.
    Thanks and Regards;
    Gadelhas
    Yes, I found that it is nec, and tried to take code from here:
    http://www.picbasic.co.uk/forum/showthread.php?t=15368
    and modified it to my needs:
    Include "modedefs.bas"  ' Include serial modes
    'DEFINES FOR LCD PORTS
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1500
    DEFINE LCD_DATAUS 44
    define osc 4
    ADCON1=%00000110 'CONFIGURE PORT A AS DIGITAL
    'TRISA=1 'CONFIGURE PORT A AS INPUT
    low TRISB
    LOW TRISC
    LOW TRISA
    Leader VAR WORD     ' will be up to 900 for a 9mS leader pulse
    BtnVal VAR BYTE[32] ' holds 32 pulse results
    DByte1 VAR BYTE     ' address byte
    DByte2 VAR BYTE     ' inverse of address byte
    DByte3 VAR BYTE     ' command byte
    DByte4 VAR BYTE     ' inverse of command byte
    X      VAR BYTE     ' loop count
    LCDOUT $FE, 1,  "test "
      PULSIN PORTC.4,0,Leader  ' leader pulse is ~9mS low-going
      IF Leader < 850 THEN Main
      FOR X = 0 TO 31          ' grab 32 incoming pulses
          PULSIN PORTC.4,1,BtnVal(X) ' now measuring high-going pulse widths
      NEXT X
      ' now we'll decode 4 bytes from 32 pulses
      FOR X = 0 TO 7               ' sort 1st 8 pulses
          IF BtnVal[X] > 150 THEN  ' > 150 x 10uS = > 1.5mS pulse period
             DByte1.0[X]=1
             DByte1.0[X]=0
      NEXT X
      FOR X = 8 TO 15              ' sort 2nd 8 pulses, etc....
             DByte2.0[X-8]=1
             DByte2.0[X-8]=0
      NEXT X
      FOR X = 16 TO 23
             DByte3.0[X-16]=1
             DByte3.0[X-16]=0
      NEXT X
      FOR X = 24 TO 31
             DByte4.0[X-24]=1
             DByte4.0[X-24]=0
      NEXT X
    LCDOUT $FE, 1, #dbyte1, " ", #dbyte2, "    "
    LCDOUT $FE, $C0,#dbyte3, " ", #dbyte4, "    "
      PAUSE 1000
      GOTO Main
    The problem is, it still does not works. It displays "0" when I press a key on remote. Sometimes, it will display something, like 4 or 170, but it never matches the key pressed and never repeats.
    Aug 2008
    Portugal
    I didn't look at the code, because i'm at work, but you should post your schematic too!
    Thanks and Regards;
    Gadelhas
    There's nothing much to post in schematic, the receiver is hooked as it should, GND goes to GND, VDD goes to VDD, and OUT is connected to PORTC.4
    Aug 2011
    Guadalajara, México
    I never tried NEC protocol before, but Sony SIRC has been worked flawlessly to me and it's very easy to decode with minimal resources, you should give a try:
    http://www.picbasic.co.uk/forum/cont...next-project!!
    Regards.
    My English doesn't sucks, it's just fugly...
    Feb 2012
    PERTH AUSTRALIA
    here is part of code i wrote to capture the IR codes for NEC protocol from a remote controlled LED RGB lamp project
    code uses a 8mhz, PIC12F683, code use IOC with darrel 's int routines
    hope it helps
    DEFINE OSC 8             ' Timing referance for pause , pauseus commands
    DEFINE PULSIN_MAX 21600  ' Maximum counts( clock ticks) allowed before pulsin times out( 21600 ^ 5ms =  108 ms)
                             ' Norm IR pulse length is 108ms
    ' =========================  Get IR Code Routine    =================
     ' *             *******  IOC - Interupt Handler routine *******     *
     GetIRcode:
          z = 0                            ' Z points to start range of byte
          S = 7                            ' S points to end range of byte
          X = 0                            ' start X at 0 to line up with BtnVal array
          y = 0                            ' Y is used for each byte
       rctime IR,0,Leader                         ' get leader low pulse time value in on GPIO.0
         IF Leader < 1700 or  Leader > 1875 tHEN  ' look for 9000us Low pulse of header for 1st or 2nd key area pulse
    @ INT_RETURN                                  ; reject if < 8500us  or > 9375us (1700^ 5us= 8500us)
       RCtime IR,1,Leader                         ' check for 1st key seq high pulse for 4.5ms after the 9ms low pulse so no repeat headers or 2nd key
         if Leader < 850  or Leader > 950 then    ' if high for < 4250us  then its the 2nkey /data at wrong or > 4750us ( invalid pulse) ( 850 * 5us = 4250us)
    @ INT_RETURN
           PULSIN IR,1,leader          ' now measuring high-going pulse widths   ( pulsin_max set to 21600 = 108ms )
           BtnVal(x) = leader/2        ' leader divide by 2 so array Btnval(x) is byte (<255) not word value
      NEXT X
      for Y = 1 to 4                       ' Get in Array and decode 4 bytes from 32 bit pulses
            T = 7                          ' Set T to 7 so that it puts BtnVal(0) in to D7 location
            FOR X = Z TO S                 ' sort 8 pulses of byte
              IF BtnVal[X]  > 120 THEN     ' > 120 x (5uS *2) = > 1.2mS pulse period = 1 (150)
                 DByteTmp = DByte[Y]       ' get into temp var
                 DByteTmp.0[T]=1           ' Set value to 0 or 1 , T reverses bit order of BtnVal(x) so byte has correct bin value to write byte
                 DByteTmp.0[T]=0           ' Set value to 0 or 1 , T reverses bit order of BtnVal(x) so byte has correct bin value to write byte
              DByte[Y] = DByteTmp          ' get it back into DByte(y)        c
              T = T - 1                    ' T points to next MSB on loop
            NEXT X
          Z = x                            ' Z = X (0,8,16,24) points to start of next byte
          S = 7 + X                        ' S  (7,15,23,31) points to End of next DByte BtnVal offset to X
      next Y                               ' loop for 4 bytes
    Thanks, but your code lacks some commands as I can see, like:
    OSCCON = %01110111
    to set OSC clock to 8mhz
    And it is quite interesting, if it's possible to decode air conditioner remote codes? they are very long and very weird
    Aug 2008
    Portugal
    OSCCON = %01110111
    You cannot assume that just by see "DEFINE OSC 8", because he can be using an external osc. You can only assume that, it he had post the config fuses.
    One more thing, about this
    What's the reference of your IR receiver? Because some need a pull up resistor, when your are not using it.
    Thanks and Regards;
    Gadelhas
    I've solved the problem, but code is quite weird
    Code looks like this:
    MAIN:
    PULSIN FLASH,1,SOMEVAR
    IF SOMEVAR<50 AND SOMEVAR >20 THEN GOTO KOUNT
    GOTO MAIN
    KOUNT:
    INCREMENT=INCREMENT+1
    IF FLASH=1 THEN POS=POS+1 ELSE NEG=NEG+1
    IF INCREMENT>1000 THEN GOTO COMPLETE
    GOTO KOUNT
    COMPLETE:
    IF POS>100 AND POS<300 AND NEG>1000 AND NEG<3000 THEN GOSUB JOB:
    POS=0:NEG=0:INCREMENT=0
    GOTO MAIN
    JOB:
    TOGGLE RELAY1
  1. remote code learning
    Last Post: - 21st February 2021, 15:38
  2. Using Walter's Servo PWM encode / decode code
    By NickMu in forum mel PIC BASIC Pro
    Last Post: - 1st November 2012, 23:17
  3. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  4. Hitachi remote code
    By aa222k in forum mel PIC BASIC Pro
    Last Post: - 26th October 2008, 23:20
  5. IR decode problem "hitachi TV remote"
    Last Post: - 13th March 2006, 15:29
